Author Topic: Running a 788ci HD and 788ci HD DI at the same time  (Read 9367 times)
Offline grae46
  • Unit(s): 998c HD SI, 788ci HD DI
« on: February 17, 2014, 02:50:59 PM »
Hi Everyone,
I got a 998 si unit this winter and installed it at the dash where my 788ci hd was before.  I currently have a 788ci HD DI at the front of the boat and want to put the 788ci hd up there to use as a map/graph.  My question is can I run the 788ci HD and 788ci HD DI at the same time or is it going to mess up the pictures from the frequencies.  I have a Minn Kota with the Universal Sonar so I would run the 788ci HD through that for the transducer if it would work.  Any help or input would be greatly appreciated!
Re: Running a 788ci HD and 788ci HD DI at the same time
« Reply #1 on: February 18, 2014, 09:23:13 AM »
You would probably get sonar interference between the 788ci HD and the 788ci HD DI units if you are using the sonar on the 788ci HD unit.  This is because both units are using the same 200kHz frequency.  Now if you set the DI unit to use the 455kHz (2D) frequency, you should not have this sonar-to-sonar interference.  Better still; turn off the sonar in the 788ci HD unit and use it for a map/GPS unit.
Last post September 22, 2010, 03:25:39 AM
by Daza67
Last post January 18, 2011, 04:08:47 PM
by navionic
Last post January 22, 2011, 01:02:32 PM
Last post April 03, 2011, 03:41:03 AM
by boat49
Last post March 28, 2011, 02:11:09 PM
Last post September 14, 2011, 07:19:26 PM
by mck1975
Last post December 10, 2011, 08:20:43 PM
by DLM10
Last post December 24, 2011, 01:24:42 PM
by SkeeterMatt
