Author Topic: Ethernet for 898c SI and 788ci  (Read 10438 times)
Offline ferney69
  • Unit(s): 2
  • Software: 5.210, 5.210
  • Accessories: 898c SI, 788ci
« on: March 24, 2011, 02:44:03 PM »
 I have a 898c SI at the console and a 788ci at the bow,  my 898 has the new 5.4 sw uploaded for ethernet. My question is do I have to wait for a sw upgrade for the 788 before I can share way points between the two units using ethernet? Or...??
« Last Edit: March 24, 2011, 03:01:31 PM by ferney69 »
Offline Trytoofish
  • Software: 2.0, 7.51,
Re: Ethernet for 898c SI and 788ci
« Reply #1 on: March 24, 2011, 03:25:04 PM »
I dont think the 788c is Ethernet capable. You need the new 788 HD for Ethernet capable
Try Too Fish  Forced To Work
« Reply #2 on: March 24, 2011, 05:09:00 PM »
Trytoofish is correct: you have to have one of the new 788ci HD or 788ci HD DI units to be able to have an Ethernet connection to another unit.  The older 788ci units (no “HD” designation in the model number) do not have the Ethernet connector or the circuitry to do this.
If you do have a 788ci HD or 788ci HD DI unit than the 5.410 Ethernet software that you need should be in your Humminbird account.  Load it into your unit and they should start sharing waypoints if connected by the Ethernet cables.
Offline ferney69
  • Unit(s): 2
« Reply #3 on: March 24, 2011, 11:35:14 PM »
Oh, ok, I see, well will they work with  interlink system then? If so do I have to remove the 5.4 sw version and reload  the 5.2 sw version on my 898c SI?
« Last Edit: March 24, 2011, 11:44:07 PM by ferney69 »
« Reply #4 on: March 25, 2011, 01:53:17 PM »
Yes it will.  however search this forum  for interlink issues.  The software has problems.  sometimes it may work and for others it does not.....
take some time to do the search.
you will find out a lot....
Offline ferney69
  • Unit(s): 2
« Reply #5 on: March 25, 2011, 07:13:30 PM »
I will do some search for sure then, thanks for your help guys.
Last post May 26, 2010, 02:51:46 PM
by terry0540
Last post September 22, 2010, 03:25:39 AM
by Daza67
Last post February 23, 2011, 03:54:29 PM
Last post April 03, 2011, 03:41:03 AM
by boat49
Last post March 23, 2011, 03:02:59 PM
Last post March 15, 2012, 10:01:39 AM
by gibsond
Last post October 22, 2012, 11:20:27 PM
by honda460ex
Last post July 02, 2014, 09:58:13 PM
by SkeeterMatt
