Author Topic: 788ci HD DI on the way  (Read 8926 times)
Offline mck1975
  • Go Bucks
  • Unit(s): 788ci HD DI
« on: August 30, 2011, 12:46:58 PM »
New kid also....after research and questioning RGecy to death, whom was very helpful, I ordered the 988ci HD DI, it should be here Wednesday. If anyone has any tips on installation and the best placement of the transducer on a 190 King Monark feel free to advise.
Sorry if this is an unnecessary thread, but I wasn't sure if asking install advise was appropriate on the other 788ci HD DI thread.
Soul Shine, It's better than Sunshine, It's better than Moonshine and Damn sure better than Rain......
Re: 788ci HD DI on the way
« Reply #1 on: August 30, 2011, 01:10:11 PM »
Congratulations on your purchase.
If you are going to mount your transducer on your transom, I'd recommend the following:
I would get one of those transducer mounting plates/pads for your boat.
It will probably take you some time to find the absolute best location for your transducer.
You may have to move it a few times.  With that plate, you only put two holes in your
transom.
Also, with your boat out of the water and the motor down at normal trim,
you need to look at your transducer from each side of the boat.
If you don't have a clear sight on each side, then the side-imaging
will not have a clear sight outwards.
Some things will have to be tested on the water, such as high speed
depth readings.  Some people have had to move their transducer up or
down several times before they were happy with the results.
Good Luck with your installation.
« Last Edit: August 30, 2011, 01:12:44 PM by ITGEEK »
Offline mck1975
  • Go Bucks
« Reply #2 on: August 30, 2011, 02:14:07 PM »
Thank you for the advise ITGEEK, I will take and use it.
Offline mck1975
  • Go Bucks
« Reply #3 on: September 14, 2011, 07:19:26 PM »
Would isolation board material work for the mounting plate?  The material is about an inch or better thick.
Last post September 22, 2010, 03:25:39 AM
by Daza67
Last post January 18, 2011, 04:08:47 PM
by navionic
Last post January 22, 2011, 01:02:32 PM
Last post April 03, 2011, 03:41:03 AM
by boat49
Last post March 28, 2011, 02:11:09 PM
Last post February 18, 2014, 09:23:13 AM
Last post March 27, 2018, 11:48:46 PM
Last post August 03, 2023, 02:39:15 PM
by Papa D
