Author Topic: 998 SI help Needed  (Read 6667 times)
Offline slam
  • Unit(s): 998
998 SI help Needed
« on: May 08, 2014, 05:25:38 PM »
Hi everyone.
 Please take a look at my screen shots & help me correct the imaging on left side side imaging.
 Screen shot is with main motor out of water, boat in still position.
Cannot get rid of line on left side.
Let me know what i should do to correct this, Thanx in advance!!!
Re: 998 SI help Needed
« Reply #1 on: May 08, 2014, 06:54:18 PM »
Did you crank up the sensitivity to demonstrate the problem better?
We are probably going to need pictures of your installation.....from the back and the side.
« Reply #2 on: May 09, 2014, 09:49:22 AM »
Welcome to the Humminbird Side Imaging Forums slam.
Bob B is right: pics of the transom area of your boat will help us help you here.
If the motor was all the way out of the water there must be something else hanging off of the back of the boat to the left side of the transducer or else the transducer or unit has an internal problem.  If there is nothing obvious to the left of the transducer (we still want to see pics) try taking the transducer off the boat and temporarily mounting it to a pole so that you can hold it down below the level of the boat in the water and rotate it around to see if that ugly line to the left of the centerline in the Si View goes away or not.
Offline slam
  • Unit(s): 998
« Reply #3 on: May 09, 2014, 08:44:19 PM »
Hope these help.
« Reply #4 on: May 12, 2014, 12:07:51 PM »
Really needed a picture of the left side of your transom as well but it doesn’t look like there is anything over there that would block the Si sonar.  I think this may all be coming from the motor mount reflection.  The only way to know for sure would be to take the transducer off and hang it from a pole so it is under the boat.  Rotate it around and see if that horizontal line in the left Si sonar goes away or not.
Last post September 18, 2010, 11:35:26 AM
Last post November 18, 2011, 06:11:48 PM
by carlg
Last post March 22, 2013, 03:31:07 PM
Last post May 24, 2014, 06:30:11 AM
by slabbacks
Last post February 14, 2017, 05:34:29 AM
by sandi
Last post February 26, 2017, 01:41:48 PM
by edwin81
Last post May 03, 2020, 07:08:44 PM
by Dave Sutton
Last post January 14, 2023, 11:57:00 AM
by Blacklab
