Author Topic: SAR TRANSDUCER UPGRADE ADVICE NEEDED  (Read 15101 times)
Offline edwin81
  • Search and recovery unit
    • ww.facebook.com/missing.persons.search.and.recovery
  • Unit(s): 1198
« on: February 24, 2017, 10:03:42 AM »
HI Folks
We run the humminbrid 1198c with the XHS-9-HDSI 180T transducer .... we are looking to upgrade the transducer for search and recovery purposes in mind. Or to possibly just purchase a second transducer the same if no upgrade is possible.
Any information on an upgradable transducer would be great.
Many thanks
Edwin
Cork City Missing Persons SAR.
Ireland
Offline abraquelebout
Re: SAR TRANSDUCER UPGRADE ADVICE NEEDED
« Reply #1 on: February 24, 2017, 12:22:39 PM »
hi
for ducer, go on DIY side scan sonar subjects, there's all you need.
Offline edwin81
  • Unit(s): 1198
« Reply #2 on: February 24, 2017, 01:01:09 PM »
Thanks for that but im not looking to do any diy tow fish.... just seeing if there is a better transducer for a transom mounting then the one we have....
« Reply #3 on: February 24, 2017, 01:43:27 PM »
 ;) see this
http://forums.sideimagingsoft.com/index.php?topic=4371.0
on diy there's lot of system, one of this called now "Lowbird" consist to have a better resolution to adjoint a Lss2 ducer on the system
read "Lowbird 2", it work good
« Reply #4 on: February 24, 2017, 02:11:06 PM »
HI Folks
Many thanks
Edwin
Ireland
There isn't any other transducer manufactured by Humminbird
HI Folks
Many thanks
Edwin
Ireland
There is no other transducer manufactured by Humminbird that will work with the 1198 that is better than the HDSI transducer ..... as abraquelebout indicated there are other ways to be creative.
Offline Rüdiger
« Reply #5 on: February 25, 2017, 04:42:09 AM »
Hi Edwin
An upgrade for the Transducher is not available, but you can switch to the latest generation Solix 15 Si. The associated Transducher with 1200Khz should allow a fantastic resolution in the close range. For the use at sea, however, you should build a Towfish.
mvh
Rüdiger
Finding is better than losing
« Reply #6 on: February 25, 2017, 10:47:21 AM »
Some users state better image performance using the dual XHS 9 HDSI 180 T Setup using the AS SILR Y cable ...
http://www.humminbird.com/Products/AS-SILR-Y/
« Reply #7 on: February 25, 2017, 03:00:22 PM »
The performance of the HB transducer for SAR leave a lot to be desired. If you are using the system in less than 40 feet of water and under 50 feet of depth with a side scan of 80 feet you will find some benefit with the system. And that depends on the amount of debris on the bottom.
Once you get over the above limits the system is difficult to portray the image you are looking for in SAR.
Another issue is the frequency of the transmitter.
HB is just now maybe starting to understand the relationship of transduce length and frequency to target display.
For SAR purposes, as stated in previous posts, the best uses will be in the limits as above. If you get outside of those then getting the transducer closer to the bottom in the use of a towfish will improve the display.
Offline edwin81
  • Unit(s): 1198
« Reply #8 on: February 26, 2017, 01:41:48 PM »
thanks for all the replies.....
We use in on our local river mostly on a low tide iscan vary from 2m to 6 m on a high tide it can vary from 10 to 16m depending on the stretch of water. the width of the rive goes from 60m to 120 m. Another unit in out are uses  a tow fish not sure what manufacturer but they paid big big money for it and ours is producing far better quality images and definition of the bottom
Last post January 22, 2011, 01:39:00 PM
Last post January 18, 2012, 02:02:13 PM
by MichBill
Last post April 02, 2012, 12:33:40 AM
by GEEMAN
Last post May 26, 2012, 01:36:47 PM
by calli1
Last post November 10, 2012, 01:13:18 PM
by tfisher
Last post January 28, 2013, 03:53:30 PM
Last post May 23, 2014, 11:27:53 PM
by rsouza3
Last post January 09, 2015, 02:12:28 PM
