Author Topic: help needed  (Read 9629 times)
Offline carlg
  • Unit(s): 858c
help needed
« on: November 14, 2011, 09:39:51 PM »
Hi everyone i need some advice. i will be getting a 2012 nitro Z7, right now i have a HB 858c, my plan is to put my 858c in the bow of the boat. now, my question is what should i get for myself behing the wheel??? i was thinking of the 998c si
also if i link these 2 units are they compatible ??? thanks for your help.
Re: help needed
« Reply #1 on: November 15, 2011, 12:45:22 PM »
Not sure what you are meaning by “compatible” carlg.
The 858c and 998c Si units can be Ethernet connected together (as can other units) and share GPS Receivers, temperature, waypoint data and some sonar (the 858c cannot use the Si/Di sonar data from the 998c Si unit).  Is that what you were meaning?
Offline carlg
  • Unit(s): 858c
Re: help needed
« Reply #2 on: November 15, 2011, 06:03:37 PM »
Hi Greg, yep you answered the question. i wasen't sure if you could interlink both units. so i could use my 858c at the bow with the transducer hooked up on the trolling motor and the 998c si tranducer hooked up to my jack plate which cable do i need to interlink both units to use the gps ????
thanks
Re: help needed
« Reply #3 on: November 15, 2011, 06:07:32 PM »
Have you looked at the AS interlink.  check HB web for description. It is under accessories....
Offline carlg
  • Unit(s): 858c
Re: help needed
« Reply #4 on: November 15, 2011, 08:28:40 PM »
sure did Greg that should do the job thanks
Re: help needed
« Reply #5 on: November 18, 2011, 10:37:07 AM »
Sorry carlg I have been conducting a solder training class all week.
The AS-InterLink that Chuck mentioned would be what you would use to InterLink those two units but – the better option would be to Ethernet connect them using one of the AS-EC cables.  These come in a variety of lengths or 2, 10, 15, 20 or 30 foot lengths.  The part numbers will tell you which length they are: AS-EC-2E is a two-foot cable, the AS-EC-10E is a 10 foot cable… and so on.  This is also the cheaper way to connect two units as well.
Offline carlg
  • Unit(s): 858c
Re: help needed
« Reply #6 on: November 18, 2011, 06:11:48 PM »
ok even better!!! thanks really appriciate the help
Last post May 06, 2010, 07:56:45 AM
Last post September 18, 2010, 11:35:26 AM
Last post April 02, 2012, 12:33:40 AM
by GEEMAN
Last post May 18, 2012, 08:04:26 PM
by Predator
Last post May 26, 2012, 01:36:47 PM
by calli1
Last post September 13, 2012, 08:44:07 PM
by calli1
Last post March 22, 2013, 03:31:07 PM
Last post February 14, 2017, 05:34:29 AM
by sandi
