Author Topic: Cables needed  (Read 10635 times)
Offline Blacklab
  • Unit(s): Helix 8N mega si Plus, Helix 7N si mega
  • Accessories: Ulterra SI Mega 80* 60"
Cables needed
« on: January 12, 2023, 10:44:36 PM »
Cables needed  for one boat network.
2 birds g3 N = 2 dongles, 2 ethernet extention cables
1 ulterra link si/di with extendtion cable
1 5 port brain
Plus neama 2000. Assumming🤪🤪🤪 plugging into 5 port.
Is there a special cable for the Tm and si/di???
Thank you
Hey now! I'm not a complete idiot, I have parts missing. Though sometimes I wonder.
Want to make god laugh, tell him your plans wink
Re: Cables needed
« Reply #1 on: January 13, 2023, 08:24:47 PM »
Are these birds HELIX G3N or SOLIX G3  ... ??
Re: Cables needed
« Reply #2 on: January 14, 2023, 10:09:26 AM »
I’m going to assume your referencing HELIX  ...
You will need 2 dongle cables - one for each HELIX head unit  ... :
https://humminbird.johnsonoutdoors.com/accessories/cables/ec-qde-ethernet-adapter-cable
You will need 2 Ethernet cables - one for each HELIX head unit  ... Ethernet cables come in various lengths …:
https://humminbird.johnsonoutdoors.com/accessories/cables?f%5B0%5D=field_product%253Afield_hbcabletype%3A27016
You will need the AS ETH 5XPG Ethernet switch  ...:
https://humminbird.johnsonoutdoors.com/accessories/cables/as-eth-5pxg-5-port-ethernet-switch
You will need to decide if you want the Minn Kota to communicate with the Humminbird units for GPS functions such as Follow the Contour and trolling motor control from the Humminbird head unit. These functions require i-Pilot Link model Minn Kota. (Non-Link model Minn Kota can still connect the built-in transducer to the Humminbird. But no GPS function control from the Humminbird head unit)  ...
Minn Kota iLink models come with a 30ft Ethernet extension cable for connecting the Minn Kota iLink to the AS ETH 5XPG for GPS communication to the Humminbird head units  ...
Minn Kota MDI and/or MSI models come with a 14 pin transducer cable (8ft I think)  ... so you will need an adapter cable to connect Minn Kota MDI transducer to a helix transducer port. Minn Kota MKR-MI-1 is 3ft long  ...:
https://minnkotamotors.johnsonoutdoors.com/accessories/trolling-motor/mi-adapter-cable-mkr-mi-1-hb-helix-8-15
NMEA is not necessary unless you are adding NMEA devices to the Network like radar  ...
Offline Blacklab
Re: Cables needed
« Reply #3 on: January 14, 2023, 11:57:00 AM »
Thanks Ricki. Yes Helix G3N. Found the I needed. Ulterra si adapter cable.
Last post February 11, 2011, 03:39:10 AM
by Rüdiger
Last post April 12, 2011, 01:07:43 PM
Last post July 14, 2011, 01:57:14 AM
by Roddy
Last post October 25, 2012, 04:40:24 PM
Last post February 24, 2013, 08:25:02 AM
by mulliemark
Last post April 29, 2013, 12:39:33 PM
Last post November 26, 2013, 08:00:55 PM
by geemul
Last post October 14, 2023, 10:40:07 AM
by Blacklab
