Author Topic: Interference from 83 kHz beam  (Read 6319 times)
JoeH
  • Guest
« on: April 06, 2014, 08:56:29 AM »
I'd appreciate any feedback about a possible cause for interference between 0 and 2.5 ft on the sonar view, when the 83 kHz beam is on.  It is unaffected by the outboard position and goes away when I switch to 200 kHz only.  The down- and side-imaging views look fine.  Here is a snapshot and picture of the installed transducer.  Thanks!
Offline sfw1960
  • Bringer Of The 'Bird
Re: Interference from 83 kHz beam
« Reply #1 on: April 06, 2014, 10:47:55 AM »
Try some shots in a bit deeper water.
You are shooting 4000 watts under an aluminum reflective surface!
When you have that much power pinging up and down between bottom & surface that many times - strange things can happen...
At 10' you can easily see the second bottom echo forming.
83 KHz is generally used in deeper water FWIW.
« Last Edit: April 06, 2014, 10:50:01 AM by sfw1960 »
« Reply #2 on: April 07, 2014, 11:59:10 AM »
You can turn the "Surface Clutter" setting down under the Sonar tab...(this setting is basically a filter)...
A lower setting is telling the unit to display "less" surface clutter...
JoeH
  • Guest
« Reply #3 on: April 07, 2014, 01:13:15 PM »
The band of interference is the same (2.5 ft) whether water is shallow or deep.  I chose a shallow example to make it easier to see.  Thanks for the tip about deeper water use of 83 kHz.
« Reply #4 on: April 07, 2014, 03:18:37 PM »
The lower the sonar frequency the worse it reflects off of surface clutter (50kHz is even worse!).  Higher frequencies work better when it comes to surface clutter.
Si vs quad beam
Started by Mudlure General Discussion
Last post June 01, 2011, 10:20:20 AM
Last post November 28, 2011, 07:01:38 PM
by cds2
Last post December 29, 2012, 10:31:01 AM
Last post January 31, 2013, 11:06:35 AM
Last post February 22, 2013, 09:18:58 AM
Last post December 04, 2013, 08:43:42 AM
Last post June 18, 2014, 01:09:03 PM
by steve reid
Last post July 30, 2021, 08:59:35 PM
