Author Topic: Di, Si, 2D, dual beam, quad beam majorly confused...  (Read 13241 times)
Offline honda460ex
  • Unit(s): 898c & 788ci
« on: December 29, 2012, 10:21:58 AM »
Sorry guys, still majorly new to this and needing help. I have a 788ci at the trolling motor with a dual beam transducer. I've been told i can get a quadrabeam transducer to get a side image view in a 2d. Is this true? Also, is there a benefit of running a quadrabeam on my 898c Si that sits at my console? It currently has two transducers. One is the Si transducer and the other is a dualbeam for operation at higher speeds. Would it benifit me at high speeds to change the dual out for a quad? If so, what's the perks and drawbacks? Would i need a switch to flip between the two transducers or just select it from my unit each time i go to run and come back to an idle? Sorry, a lot of questions flying in here.
« Last Edit: December 29, 2012, 10:25:17 AM by honda460ex »
Re: Di, Si, 2D, dual beam, quad beam majorly confused...
« Reply #1 on: December 29, 2012, 10:26:04 AM »
Good questions.  Yes you can get a switch to go between the two transducers. You may have to select the transducer type on your display.
« Reply #2 on: December 29, 2012, 10:31:01 AM »
The switch is the TS3 .... also look at this link to HB site..https://www.google.com/url?q=http://store.humminbird.com/media/document/TS3.pdf&sa=U&ei=TQzfUKyFM4Lh0gHi8oHoBw&ved=0CAcQFjAA&client=internal-uds-cse&usg=AFQjCNF4oNQSTlgiN0W0KurlXNPU56YHOQ
 We use this switch to go between two ducers and it works well...
Si vs quad beam
Started by Mudlure General Discussion
Last post June 01, 2011, 10:20:20 AM
Last post August 05, 2011, 08:19:02 AM
Last post November 28, 2011, 07:01:38 PM
by cds2
Last post December 05, 2011, 12:20:17 PM
Last post October 25, 2012, 10:44:27 AM
by harporocks
Last post December 26, 2012, 10:16:08 AM
Last post July 14, 2016, 02:53:06 AM
by fishreed
Last post August 08, 2022, 09:30:29 PM
