Author Topic: Dual beam or Quad Beam  (Read 13972 times)
Offline cds2
  • Unit(s): 788ci
« on: November 27, 2011, 07:00:55 PM »
Hi, i have a 788ci witch needs a new transducer. I would like  to get a bit of advice on weather it is worth going for the Quad Beam or If the Dual beam is just as good. I have had it for 3 years now and this is its 3rd transducer. Is that normal or should the transducers last longer than that?
Offline George
  • Software: Always up todate
Re: Dual beam or Quad Beam
« Reply #1 on: November 28, 2011, 07:46:27 AM »
cds2
I have a Quadra beam on my TM but use mostly the dual beam part of it.  If you get a Quadra Beam you will have a choice of using 83 and/or 200 khz or Quadra Beam on your unit.
Maybe getting the quadra beam is your best choice it gives you the 4 choices (4th being the combined 83/200 khz choice)
George
Offline cds2
  • Unit(s): 788ci
« Reply #2 on: November 28, 2011, 07:01:38 PM »
Thanks, i have ordered a Quad Beam, will try it as soon as it get here
Si vs quad beam
Started by Mudlure General Discussion
Last post June 01, 2011, 10:20:20 AM
Last post August 05, 2011, 08:19:02 AM
Last post December 05, 2011, 12:20:17 PM
Last post December 29, 2012, 10:31:01 AM
Last post December 04, 2013, 08:43:42 AM
Last post July 14, 2016, 02:53:06 AM
by fishreed
Last post August 08, 2022, 09:30:29 PM
Last post October 08, 2022, 09:00:08 PM
