Author Topic: Si vs quad beam  (Read 10056 times)
Mudlure
  • Guest
Si vs quad beam
« on: May 31, 2011, 08:11:27 PM »
Can someone in laymans terms explain to me the difference in Si and quadbeam?
What happens when I change the sonar from si to quad and then back?
What does si do that quad doesnt and which frequencies are for which beam?
Muddy
Offline Del
  • Unit(s): 1197 SI
Re: Si vs quad beam
« Reply #1 on: June 01, 2011, 01:08:47 AM »
Side Imaging:
http://www.humminbird.com/SonarContentWireFrame.aspx?Pageid=2664&id=2868
Quad Beam:
http://www.humminbird.com/leading_innovation/humminbird-sonar/quadrabeam-plus.aspx
In other words: Side Imageing is giving the NICE pictures to you. Quad looks like a standard sonar to you, just got a greater coverage.
Re: Si vs quad beam
« Reply #2 on: June 01, 2011, 10:20:20 AM »
As Del showed you; it’s all in the shape and size of the Si sonar beams versus the QuadraBeam sonar beams.  Since the Si beams are very thin front-to-rear and very wide left-to-right they can produce an image that has a lot of detail that also covers a wider area than the QuadraBeam can.
When you change the Transducer select menu from one setting to another, the unit will use a different part of programming for one sonar type versus another.  Not only will sonar Views change but also associated menus will be shown or hidden as well.
Last post January 25, 2011, 07:50:17 PM
by Trytoofish
Last post August 05, 2011, 08:19:02 AM
Last post November 28, 2011, 07:01:38 PM
by cds2
Last post December 05, 2011, 12:20:17 PM
Last post December 29, 2012, 10:31:01 AM
Last post December 04, 2013, 08:43:42 AM
Last post August 08, 2022, 09:30:29 PM
Last post October 08, 2022, 09:00:08 PM
