Author Topic: Transducer Swap Out and Shield Saver  (Read 13322 times)
Offline Bayou Basser
  • Unit(s): Helix 5 Chirp DI GPS G3, Helix 7 Chirp M
  • Accessories: None
« on: March 24, 2014, 03:10:37 PM »
Well I bit the bullet and ordered an 899ci HD SI unit today.  I ordered it from the Humminbird Outlet Store and they cannot ship it with the XHS-9-HD-SI-180T Transducer.  Is there an extra charge for the swap out for this transducer?  Also, Shield Saver, Inc. makes a shield (TM-HSI) for mounting the HD transducer on the trolling motor.  Does anyone know about this product and can give me some advice on it?
Re: Transducer Swap Out and Shield Saver
« Reply #1 on: March 24, 2014, 03:44:15 PM »
Yes, there is an extra charge for the HDSi transducer.  Call the Humminbird Customer Resource folks to find out what it is.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: March 24, 2014, 10:42:22 PM »
Which trolling motor are you using? I have a Minn Kota maxxum 55# bow mount and they had to modify the standard bracket. Depends where the
skeg is located.
           Mike
  • Accessories: None
« Reply #3 on: March 25, 2014, 11:13:26 AM »
Thanks newkid4si.  The trolling motor is a Motor Guide 54lb thrust model FW-FB.  It looks like the shield will install ok but I wanted to make sure it does protect the transducer and does not interfere with the signals.
  • Accessories: None
« Reply #4 on: March 25, 2014, 11:53:17 AM »
I just read some earlier posts concerning the TM-HSI shield saver and it looks like it is a good product and works well.  So we all can ignore this post.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #5 on: March 25, 2014, 12:04:28 PM »
I think the deciding factor is if you can get a flat surface the lenght of the shield for mounting, you'll be OK.
My motor has a 1/8" step where the motor surface meets the skeg housing. Greg is posting my install photos later.
Transducer S&S have been great people to work with.
           Mike
Offline bgump24
  • Unit(s): 899 SI
« Reply #6 on: March 30, 2014, 09:08:46 AM »
I installed the trans saver on my motorguide it fits great works good
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #7 on: April 02, 2014, 07:36:00 PM »
$85 from CSI  to HDSI
Last post August 03, 2010, 02:15:46 PM
Last post September 22, 2010, 03:01:36 PM
by Daniele_Mari
Last post January 23, 2011, 06:46:33 AM
by stillbear
Last post February 13, 2012, 01:27:54 PM
by bamafish
Last post February 20, 2014, 10:27:16 AM
Last post March 23, 2014, 01:56:00 AM
Last post March 19, 2015, 03:47:10 PM
Last post April 24, 2016, 11:41:54 AM
