Author Topic: Transducer Swap  (Read 7908 times)
Offline Kountrykool
  • Unit(s): 598ci hd si & 899ci hd si
Transducer Swap
« on: February 20, 2014, 07:55:10 AM »
Is there a benefit to swapping out my 859 di transducer.  I was told that there is one for a trolling motor. If so what is it? Im headed to Eufaula, Al to do the swap. I hope its worth the drive. Im only 80 miles away from Hummingbird.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Transducer Swap
« Reply #1 on: February 20, 2014, 08:27:03 AM »
The benefit is it is shaped to fit the trolling motor and has shielding to reduce interference. Less likely to get damaged too. Bob
Re: Transducer Swap
« Reply #2 on: February 20, 2014, 09:10:09 AM »
In addition to what bobcoy mentioned...
The stock XNT 9 DI T is ...455kHz 16°/200kHz 25° 2d cones ...and 455kHz 75°/200kHz 45° DI slices...
The XTM 9 WIDE DI 20 T is ...83kHz 60°/200kHz 20° 2d cones...and 455kHz 75°/200kHz 45° DI slices...
Offline bobcoy
Re: Transducer Swap
« Reply #3 on: February 20, 2014, 10:23:18 AM »
In addition there is an XTM 9 DI 25 T It has the same values at the transom transducer. I have no idea which one is best under differing fishing situations. Maybe someone can shed some light on this. Bob
Re: Transducer Swap
« Reply #4 on: February 20, 2014, 10:27:16 AM »
Bob,
It just gets back to what 2D sonar frequencies you want to use and/or how wide of a sonar beam you want.  You could run the 200/455kHz version at the 455kHz frequency to try and avoid sonar cross-talk with another unit that is using 200kHz 2D sonar or opt for the increased 2D sonar coverage of the 83kHz 2D sonar on the WIDE version DI transducer.
Kountrykool,
I think I missed you when you came by to swap the transducer earlier today.  Sorry but I was stuck in a meeting at the time.
by Sonshine Fishing
Last post February 10, 2012, 05:50:59 AM
by genejohn
by Brian37075
by jgcox6
Last post April 29, 2013, 01:34:51 PM
Last post April 02, 2014, 07:36:00 PM
Last post April 24, 2019, 01:04:43 PM
by slabbacks
