Author Topic: Installing a transducer shield  (Read 13493 times)
Offline tennwalkinghorse
  • Unit(s): 898cSI
  • Software: 6.420
« on: July 20, 2010, 09:44:12 PM »
I just ordered a 898c SI I was planing to mount the transducer on the trolling motor. I ordered one of the Transducer shield & savers to protect the transducer. Can this be used with SI type transducers or will it cause interference? The transducer shield & saver was model number SSC - 3.
Thanks for your input,
Mike
« Last Edit: July 20, 2010, 09:51:54 PM by tennwalkinghorse »
Offline calli1
  • Unit(s): 1198 S I & 787c2i
Re: Installing a transducer shield
« Reply #1 on: July 20, 2010, 10:51:33 PM »
I personally do not think a shield will work on the S I ducers.
Someone will follow my post with a answer you can use.
Good Luck.
« Reply #2 on: July 20, 2010, 11:07:56 PM »
The Transducer Shield and Saver DOES work with the SI Transdcuers.  But, the one you need would be the  TM-HDSI.
The SSC-3 is for a standard Humminbird 2d transducer and will not work with the HB SI Transducers.
« Last Edit: July 20, 2010, 11:10:55 PM by RGecy »
  • Unit(s): 898cSI
  • Software: 6.420
« Reply #3 on: July 22, 2010, 05:37:50 PM »
Thanks for the info guys I sent the other stuff back and ordered the right stuff.
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #4 on: July 22, 2010, 09:15:46 PM »
Yes I have 997 mounted on my TM with a transducer saver works great.  Gary
  • Unit(s): 898cSI
  • Software: 6.420
« Reply #5 on: August 02, 2010, 07:11:37 PM »
Right transducer shield came on Saturday installation went great man is that a SOLID mount. Much better then the OEM mount. Sorry Humminbird just calling it like I see it. Now need time to play with it on the water. Thanks all for the back up .
« Reply #6 on: August 03, 2010, 02:15:46 PM »
No apology needed.
I’ve seen that mount first hand and it is ROCK SOLID!
Last post September 22, 2010, 03:01:36 PM
by Daniele_Mari
Last post January 23, 2011, 06:46:33 AM
by stillbear
Last post February 13, 2012, 01:27:54 PM
by bamafish
Last post March 23, 2014, 01:56:00 AM
Last post April 02, 2014, 07:36:00 PM
Last post March 19, 2015, 03:47:10 PM
Last post April 24, 2016, 11:41:54 AM
Last post August 24, 2016, 10:47:56 PM
