Author Topic: TRANSDUCER SHIELD  (Read 11825 times)
Offline ddrenuf
  • Unit(s): 798csi
  • Accessories: weathersense
TRANSDUCER SHIELD
« on: September 20, 2010, 09:50:18 PM »
WHAT TRANSDUCERSAVER AND SHIELD DO I NEED. I MOUNTED THE TRANSDUCER ON THE TROLLING MOTOR?
Wayne P.
  • Guest
Re: TRANSDUCER SHIELD
« Reply #1 on: September 21, 2010, 06:57:46 AM »
What sonar unit and trolling motor do you have?
I have the TM-HDsi Transducer Shield and Saver for the HDSI transducer on a Motor Guide Tour edition.
Offline Daniele_Mari
    • Italy B.A.S.S. Federation Nation
  • Unit(s): 798ci SI Combo
  • Software: 4.960
« Reply #2 on: September 21, 2010, 07:02:59 AM »
I bought the other one for the ducer that I found in the box ..
http://www.transducershieldandsaver.com/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=10&category_id=5&option=com_virtuemart&Itemid=55
Wayne, Do you have the HDSI ducer ?
Have you noticed some differences ?
Ciao
Daniele
Daniele from Italy
www.italybass.com
« Reply #3 on: September 21, 2010, 09:02:07 AM »
ddrenuf,
We would need to know which transducer you have or are planning on using on the trolling motor with your 798c Si unit.  WayneP decided to go with the larger HDSi transducer that comes with the 898, 997, 998, 1197 units and the TM-HDsi bracket from Transducer Shied & Saver.
Which transducer you plan on using will dictate which bracket you will need to get:
XNT-9-Si-180-T (standard Compact Side Imaging transducer that comes with the 798 units) will need the TM-Csi
XTM-9-Si-180-T (trolling motor mount Compact Side Imaging transducer) does not need a bracket from TS&S.
Daniele,
Not everyone notices it but you should notice some added resolution to the Si sonar in the 798 unit when using the larger HDSi transducer.
Wayne P.
  • Guest
« Reply #4 on: September 21, 2010, 01:18:08 PM »
Daniele, yes I got the HDSI transducer from Humminbird since I could not get rid of TM interference with the trolling motor compact SI transducer I purchased last year or the compact SI transducer that came with the 798.
 When I installed the HDSI transducer a couple of months ago, I immediately noticed a clearer image with SI.
  • Software: 4.960
« Reply #5 on: September 22, 2010, 03:01:36 PM »
Thanks you all and sorry for the off topic.
Daniele from Italy
www.italybass.com
Last post August 03, 2010, 02:15:46 PM
Last post January 23, 2011, 06:46:33 AM
by stillbear
Last post February 13, 2012, 01:27:54 PM
by bamafish
Last post September 30, 2013, 12:33:15 PM
Last post March 23, 2014, 01:56:00 AM
Last post April 02, 2014, 07:36:00 PM
Last post March 19, 2015, 03:47:10 PM
Last post April 24, 2016, 11:41:54 AM
