Author Topic: Need Some Help, interference problems on 898  (Read 6094 times)
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« on: September 19, 2013, 05:43:45 PM »
Ok....I'm in the process of nailing down what my problem is here.  I know it has to do with wires probably touching somewhere.  When I added this to my trolling motor...this is on my down image only with some small interference when on side image setting but nothing like this.  I have added some filter/chokes but no luck.
This interference is when the trolling motor is not on also.    Now...this white looking interference would have continued across if I had left along long enough.  Any ideas.......
« Last Edit: September 19, 2013, 07:33:26 PM by calli1 »
Offline calli1
Re: Need Some Help, interference problems on 898
« Reply #1 on: September 19, 2013, 05:45:16 PM »
This interference is when the trolling motor is not on also.  And if I would have let it...the interference would have covered the entire screen.
« Last Edit: September 19, 2013, 07:54:10 PM by calli1 »
Offline Poorman
  • Unit(s): 898c
  • Software: 6.740
« Reply #2 on: September 19, 2013, 08:31:15 PM »
Its a flaw with the software. I just went through this myself after upgrading software 6.64.
I did a restore and it went away. Run it today for about 3 hrs and still hold good after I installed the 6.740 software update. If you look under the 898 post you will see more info about it.
Offline calli1
« Reply #3 on: September 19, 2013, 08:40:00 PM »
So...what do I need to do.... ?   Do I need to restore the software in the unit then ?
« Reply #4 on: September 19, 2013, 09:26:04 PM »
This is a known bug in the DI Enhance Sharpness setting...(started somewhere around 6.570)...
Set the DI Sharpness to Off...
« Last Edit: September 19, 2013, 09:28:40 PM by rnvinc »
Offline calli1
« Reply #5 on: September 19, 2013, 09:55:20 PM »
Well....went ahead an installed the new 6.740 software.  I had already updated my 1198 with this and went online at Humminbird and downloaded the latest for the 898.  Seems ok now.
« Reply #6 on: September 20, 2013, 03:24:16 PM »
Turn the DI Sharpness on and see if HB fixed the this bug in the 6.740...
I have not heard yet...
Last post January 12, 2010, 07:43:29 PM
by garyr
Last post March 23, 2010, 05:50:57 PM
by fishmanmike
Last post April 09, 2010, 01:04:59 PM
Last post October 04, 2010, 06:26:54 PM
Last post December 20, 2010, 10:30:22 AM
Last post February 23, 2011, 05:07:14 PM
Last post May 16, 2013, 05:27:48 PM
Last post July 22, 2013, 05:37:19 PM
by jimmythegreek
