Author Topic: SI interference  (Read 21093 times)
Offline fishmanmike
  • Unit(s): 998c si, 788c
  • Accessories: AS-SYSLINK, US2-W SWITCH, XHS-9-HDSI-180
SI interference
« on: March 14, 2010, 08:16:10 PM »
I got my 998c si installed and it works well. I am having trouble though when I run my trolling motor at low rpms. I get severe interference on the side scan and down scan screens. If I increase the rpm's the interference goes away. I don't get any interference from my primary motor. Any ideas on how to resolve this?
bobcoy
  • Guest
Re: SI interference
« Reply #1 on: March 14, 2010, 08:49:27 PM »
More than likely it is RF interference. Most trolling motors use pulse width modulation and unless you put them on full power they put out radio waves that show up on your depth finder as lines or just a solid blob of interference. If you call support they will probably send you an interference kit. It helped me out with my Minn Kota interference. Bob
Offline fishmanmike
Re: SI interference
« Reply #2 on: March 14, 2010, 09:09:51 PM »
Thanks for the reply, I will give that a try.
Offline fishmanmike
Re: SI interference
« Reply #3 on: March 15, 2010, 04:27:15 PM »
I guess i need to clarify my statement. My trolling motor is a mercury 9.9 outboard. It has resistor plugs in it.
 I talked with Humminbird and verified tha I have nickle insulated transducer wires. They are tryin gto tell me it is turbulance but I know that is not correct. I should be recieving my sd card today or tomorrow so hopefully I can get back up to the lake to get some snapshots of the screen to send them.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: SI interference
« Reply #4 on: March 15, 2010, 04:32:06 PM »
Mike,
can you post some pictures of the transducer location (from side and rear/front) and where the TM is mounted. I guess you got the transducer on the transom and the TM on the bow, right?
Regards / Harry
YES,......
WE SCAN!
Offline fishmanmike
Re: SI interference
« Reply #5 on: March 15, 2010, 07:12:08 PM »
Here are some picts of the transducers. You can see the Black Mercuy outboard shaft is well aft of the left transducer
Re: SI interference
« Reply #6 on: March 15, 2010, 07:21:05 PM »
Mike,
Some pictures/snapshots of what you are seeing on the screen will help a lot!
Like the boat!  ;D
Offline fishmanmike
Re: SI interference
« Reply #7 on: March 15, 2010, 07:37:53 PM »
Thank You, I just recieved my sd card in the mail today and figured out how to work the snapshots on the simulator and save them in my computer. Now I just have to find time to get back up to a lake to get some samples of what is going on.
Re: SI interference
« Reply #8 on: March 16, 2010, 05:41:24 PM »
It could be motor noise interference instead of RF-trolling motor interference.  Try some of the suggestions shown here on the web site:
http://www.humminbird.com/support/FAQ.aspx?faqtopic=17
Offline fishmanmike
Re: SI interference
« Reply #9 on: March 16, 2010, 09:55:16 PM »
Well, as far as my office is concerned, I had a very important meeting to go to this afternoon. Which really meant I got up to the lake to get some screen captures. I methodically turned things on or off and realized it is my TR-1 auto pilot causing the problem . It creates no interference in standby but when it is steering ,that is when I get the problem. What can I possibly do to correct this?
<a href="http://s110.photobucket.com/albums/n85/fishmanmike/?action=view&current=noisefilterhigh.png" target="_blank"><img src="http://i110.photobucket.com/albums/n85/fishmanmike/noisefilterhigh.png" border="0" alt="noise filter high">[/url]
<a href="http://s110.photobucket.com/albums/n85/fishmanmike/?action-view&current=noisefilterhigh.png" target="_blank"><img src="http://i110.photobucket.com/albums/n85/fishmanmike/noisefilterhigh.png" border="0" alt="noise filter high">[/url]
« Last Edit: March 16, 2010, 10:06:04 PM by RGecy »
Offline fishmanmike
Re: SI interference
« Reply #10 on: March 16, 2010, 09:57:11 PM »
Picture 2 shows the interference, Picture 3 shows turning the autopilot from active to standby.
Re: SI interference
« Reply #11 on: March 17, 2010, 08:21:50 AM »
Mike, is the jet drive running when this happens.  Chuck
Re: SI interference
« Reply #12 on: March 23, 2010, 10:51:18 AM »
Fishmanmike,
You can try isolating the Humminbird and the Autopilot from each other: route any cables as far away from each other as you can.  Power them off of separate batteries.  Although made for interference from trolling motors the trolling motor interference kit from Humminbird may help with this.  Give them a call at 1-800-633-1468 and see if they can get one shipped out to you.
Offline fishmanmike
Re: SI interference
« Reply #13 on: March 23, 2010, 05:50:57 PM »
Thanks Greg, I e-mailed the same photos to Ms. Smith at Humminbird so hopefully she will respond soon. Mike
Last post January 12, 2010, 07:43:29 PM
by garyr
Last post April 09, 2010, 01:04:59 PM
Last post July 27, 2012, 08:01:52 AM
by ZX225SK
Last post May 20, 2010, 10:13:57 PM
by justfishin
Last post June 10, 2010, 09:46:46 AM
by jimf
Last post June 06, 2010, 07:19:31 AM
by Timo
Last post April 24, 2012, 12:01:35 AM
by Gattlin
Last post October 04, 2010, 06:26:54 PM
