Author Topic: 200 khz interference  (Read 10624 times)
Offline FriscoSpices.Com
« on: April 04, 2010, 11:26:01 AM »
I am installing my 1197 and a lowrance flasher on the back of my boat. I have been told the two will interfere with each other. Can the 2 units both run without interference? I need to have my flasher on when back trolling so I wanted to know the best approach for flawless images.
Re: 200 khz interference
« Reply #1 on: April 04, 2010, 01:17:02 PM »
As long as you dont have any frequencies that are the same you should be ok.  Not sure of the flasher freq but check your document and compare to the HB transducer.  chuck
« Reply #2 on: April 04, 2010, 07:33:08 PM »
the flasher is 200 khz
Offline Blackwaterkatz
  • Unit(s): 797c si / 998c si / 1198
  • Software: 5.450 / 5.700
  • Accessories: weathersense
« Reply #3 on: April 04, 2010, 10:01:13 PM »
I run a Lowrance unit with 200 mhz on one side, and a HB 797 on the other with minimal interference; more noticeable when on SI, actually.  I set the noise filter on the HB to low and it usually eliminates the interference.  If I happen to need to eliminate all interference temporarily, I just stop the chart on the Lowrance until I need it again.  Adjusting the ping rate on the Lowrance will help, too.
Tommy in Lowcountry S.C.
« Reply #4 on: April 05, 2010, 07:37:22 AM »
You can turn off the humminbird 2d transducer  thats the 83/200.  it is an option on your sonar menu.  chuck
« Reply #5 on: April 09, 2010, 01:04:59 PM »
Turning off the Sonar in the Humminbird will turn off all sonar in the unit Chuck – both the 2D frequencies (200/83kHz) and the Si frequencies (455/800kHz).
If you start showing interference on the 1197 try turning on and up the Noise Filter menu as Blackwaterkatz suggested.  No guarantees that this will work well enough, if you will need it at all or if all of the interference will show up on the flasher.  When running two sonar units at the same frequency sonar-to-sonar interference is always a possibility.
Last post January 12, 2010, 07:43:29 PM
by garyr
Last post March 23, 2010, 05:50:57 PM
by fishmanmike
Last post July 27, 2012, 08:01:52 AM
by ZX225SK
Last post May 20, 2010, 10:13:57 PM
by justfishin
Last post June 10, 2010, 09:46:46 AM
by jimf
Last post June 06, 2010, 07:19:31 AM
by Timo
Last post April 24, 2012, 12:01:35 AM
by Gattlin
Last post September 10, 2010, 10:59:59 AM
