Author Topic: Model-screen problem 141c  (Read 7437 times)
Offline yohadiko
  • Unit(s): matric
« on: July 14, 2013, 06:56:16 AM »
My problem is that every time I turn on the screen the sound of twittering at the lighting and the screen appears only the corner for a few seconds and then completely disappeared.
Does anyone know the problem?
Intentions are gladly accepted!
Thanks in advance.
Re: Model-screen problem 141c
« Reply #1 on: July 16, 2013, 12:03:33 PM »
Welcome to the Humminbird Side Imaging Forums yohadiko.
I am not understanding what you are saying here.  Do you mean that the display goes completely dark after it starts up?
Offline yohadiko
  • Unit(s): matric
« Reply #2 on: July 26, 2013, 09:26:43 AM »
tnx you sir
yes the scren becum blake and dark, i knoe the davice work but can't see anything on scren
« Reply #3 on: July 26, 2013, 11:41:15 AM »
I would check the power connections going to the unit yohadiko.  Make sure that none are loose or corroded (dirty).  You can try testing it on someone else’s boat that has a Humminbird sonar unit as most use the same power cable and a transducer that will work for the test.  Otherwise you should contact your local Humminbird repair center and get your unit looked at.
Last post January 16, 2012, 02:24:13 PM
Last post May 31, 2012, 09:14:31 AM
by BCLII
Last post June 14, 2012, 07:01:39 PM
by ctf58
Last post June 25, 2012, 12:04:08 PM
Last post November 21, 2012, 10:06:17 AM
Last post September 13, 2012, 09:40:58 AM
Last post March 29, 2013, 02:16:11 PM
Last post May 07, 2014, 04:37:40 AM
by peterv6i
