Author Topic: Losing depth reading on 1198c  (Read 8203 times)
Offline muskyjeff84
« on: July 03, 2013, 03:12:31 PM »
Was out yesterday and had trouble off and on with my depth reading on my 1198c.  Worked fine about half of the time but would change to 2.2 feet and locked on that number for quite a while.  Seemed to do it in both shallow and deep water.  The map screen seemed to work fine.  Any ideas of what could cause this?
Offline lapworth2005
  • Unit(s): 1198c
Re: Losing depth reading on 1198c
« Reply #1 on: July 04, 2013, 12:12:32 PM »
- make sure you have the lastest firmware installed.
- check to see if your transducer has been lifted out of the water (or is pointed on an angle)....sometimes this happened to me. just need to push it back down.
« Reply #2 on: July 06, 2013, 12:27:14 PM »
If that does not help muskyjeff84, tell us what transducer(s) you have connected to your 1198 unit and where it/they are mounted.
Sometimes setting the Surface Clutter menu to a higher setting can help with this as can setting the Water Type menu to the Salt (deep) setting.
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post May 31, 2011, 04:52:22 PM
Last post October 31, 2012, 03:42:56 PM
Last post March 04, 2013, 08:24:35 PM
by nicko_cairns
Last post January 27, 2013, 05:29:20 PM
by hvychev77
Last post February 24, 2013, 07:54:54 PM
by G4bama
Last post July 02, 2013, 02:27:26 PM
Last post August 29, 2013, 08:49:38 AM
by themothaship
