Author Topic: 998C HD SI losing depth readings while on plain  (Read 8083 times)
Offline Bombercraw
  • Unit(s): 998C SI
« on: July 01, 2013, 04:49:44 PM »
I recently purchased and installed an 998 C HD SI on my Triton.  I have noticed that I lose my depth readings when on plain.  I have the transducer mounted in the center of the transom fairly low (just below the two livewell intake screens) in order to avoid interference with anything that would affect the side scan capability.  Obviously there is interference coming from the hull in that area when on plain.  Is it possible to install a through hull transducer that would work in conjunction with the side scan transducer so that I would not lose my depth reading when on plain?  Any help would be appreciated.
Offline 4d-rock
  • Unit(s): 997c SI, 778c, 570
  • Software: 6.30
Re: 998C HD SI losing depth readings while on plain
« Reply #1 on: July 02, 2013, 10:18:44 AM »
Is it possible for you to post some pictures of the transom from various angles?  Allows for a better assessment of the situation and can lead to some better suggestions.
« Reply #2 on: July 02, 2013, 02:27:26 PM »
Yes, an XP-9-20 DualBeam inside-the-hull (aka: “shoot-thru” or “thru-hull”) transducer can be installed along with the AS-Si-DB-Y cable for the best possible high-speed water depth readings.
Last post March 08, 2011, 08:20:37 PM
Last post January 04, 2012, 02:02:55 PM
Last post January 27, 2013, 05:29:20 PM
by hvychev77
Last post February 24, 2013, 07:54:54 PM
by G4bama
Last post July 06, 2013, 12:27:14 PM
Last post April 10, 2014, 12:41:57 PM
Last post June 10, 2014, 11:49:58 AM
by biggs aquaholic
Last post October 25, 2014, 02:56:14 PM
by DiveExplorer
