Author Topic: 998c SI depth readings  (Read 9926 times)
Offline mvallery
  • Unit(s): 997, 597
  • Software: 6.7
« on: April 06, 2014, 03:37:36 PM »
Got 998 and was working perfectly.  Bought new lakemaster south card and installed update 6.74.  Went to lake yesterday and depth would stick at certain depth.  Would read same depth until turn unit off and reboot and would again go to depth and stay on that depth.  Is it software problem?  Run 2 transducers, one in hull and side scan on back of boat.  Side and down work, shows depth on down image but depth reading wrong.  Help!!
Re: 998c SI depth readings
« Reply #1 on: April 06, 2014, 09:42:01 PM »
It's possible you may have some issue in the software...but there are some things you can check first...
You might try bypassing the AS SIDB Y cable to troubleshoot...
Plug the HDSI directly into the unit and test...
Then change the "Transducer Select" menu to Dual Beam ...plug the thru hull into the unit and test again...
If the issue remains, it may be the software...then you may have to load the previous version and reload a fresh copy of 6.740 into the unit...
« Reply #2 on: April 07, 2014, 02:58:03 PM »
Do you remember this certain depth that the unit would stick to?
Offline mvallery
  • Unit(s): 997, 597
  • Software: 6.7
« Reply #3 on: April 09, 2014, 08:32:15 PM »
Seemed to be different everytime
Offline mvallery
  • Unit(s): 997, 597
  • Software: 6.7
« Reply #4 on: April 09, 2014, 10:36:39 PM »
Maybe 1.6 but I do remember a 4 something also
« Reply #5 on: April 10, 2014, 12:41:57 PM »
When you installed the 6.740 software the unit reset its menus to the factory defaults.  So you may need to go in and set some of these menus back to previous settings.  I was thinking that if that certain depth was only a few feet deep; than possibly adjusting the Surface Clutter menu could help.  Also you can try adjusting the Water Type to “Salt (deep)” to see if that helps.  Than I would try the transducers per Rickie’s suggestion.
Last post March 08, 2011, 08:20:37 PM
Last post October 18, 2011, 04:41:50 PM
Last post January 04, 2012, 02:02:55 PM
Last post June 15, 2012, 04:16:05 PM
by fishawk
Last post July 02, 2013, 02:27:26 PM
Last post December 31, 2014, 09:54:15 AM
Last post June 10, 2014, 11:49:58 AM
by biggs aquaholic
Last post October 25, 2014, 02:56:14 PM
by DiveExplorer
