Author Topic: Finally found a great waterproof 12v voltage regulator!  (Read 9488 times)
Offline Rotus623
  • Software: 6.49
« on: May 15, 2013, 12:02:58 PM »
As some of you guys know, the older outboards do not have voltage regulation on them. I read all the way up to 17.8 volts coming out of my motor at full throttle!! The HB units are supposed to be rated for 10-20V, but honestly I want to keep it at 12v, period. As Greg had stated in another thread, one of the killers of these units is too high of a voltage coming into them. The volts can sneak by without blowing the fuse, which can create mayhem for our units! So here's what I ordered. For around $30 it is cheaper, easier (and way lighter) than a separate battery. It has capacitors so that when the voltage drops during starting the motor, it will help keep the volts up (all the way down to 8v) It also will prevent spikes up to 40v (which we should NEVER see in a properly function system. I'll do some testing once I get the unit and let you guys know how it goes. http://www.amazon.com/HOSSEN%C2%AE-Converter-Regulator-8V-40V-Sealed/dp/B00BWIA0BS/ref=sr_1_1?ie=UTF8&qid=1368632887&sr=8-1&keywords=HOSSEN%C2%AE+DC-DC+Converter+Regulator+8V-40V+Step+Down+to+12V+6A+72W+Epoxy+Sealed
Re: Finally found a great waterproof 12v voltage regulator!
« Reply #1 on: May 16, 2013, 11:18:23 AM »
A voltage regulator may be cheaper and lighter
than a separate battery, but at the risk of
introducing electrical interference into your sonar.
Even with a separate battery, some people have
interference from other devices.
You are basically hooking your sonar to a battery charger
that is going to be on anytime your main motor is
running. This can't be good to get the best performance out of
your sonar.
However, the sonar should work great when your main
motor is completely turned off.
A quick test is to turn on your sonar (with main motor off).
While looking at the sonar screen, start up your main motor.
In neutral, rev your main motor up and down, and watch your sonar screen.
If you see any static, snow, lines, dots that weren't there with the main motor
off, then you have problem.
« Last Edit: May 16, 2013, 11:20:31 AM by ITGEEK »
Offline Rotus623
  • Software: 6.49
« Reply #2 on: May 16, 2013, 09:15:37 PM »
Yea I actually had some interference with main motor on with a separate battery. It wasn't bad though. I guess we'll see how it goes. I will be doing most of my scanning with my electric motor anyway.
Last post December 23, 2010, 06:31:22 PM
Last post June 28, 2011, 02:15:17 PM
by stillbear
Last post May 07, 2012, 06:04:28 PM
by depark1
Last post January 17, 2013, 12:11:30 PM
Low Voltage
Started by spes 798c SI
Last post January 27, 2013, 03:23:36 PM
by strawdg
Last post April 09, 2013, 10:40:21 AM
by jepik
Last post November 07, 2013, 01:07:44 PM
by matt@reefmaster
Last post February 21, 2022, 11:01:01 AM
by FishinLite
