Author Topic: Waterproof grommet  (Read 6844 times)
Offline TimTDP
  • Unit(s): Solix 10
  • Accessories: Minn Kotta Ultera
Waterproof grommet
« on: February 19, 2022, 09:18:45 AM »
I need to drill a hole to feed a cable to my console. The cable has connections on both ends. I am looking for a waterproof grommet to seal the hole. Or any other method.
Thanks in advance
Re: Waterproof grommet
« Reply #1 on: February 19, 2022, 11:20:17 PM »
Most run the cable up and thru the splashwell drain hole  ... and then back under the rear deck to the console  ...
Is this not an option with your application ..??
Offline TimTDP
  • Unit(s): Solix 10
« Reply #2 on: February 20, 2022, 12:38:27 AM »
Thanks you, but unfortunately not.
I need to run an ethernet cable from my bow-mounted trolling motor. So the cable has to enter the anchor locker.
Offline danlaboucane
  • Unit(s): ,798 hd onix8 ct , solix 12 msi
  • Software: 7.6 ,3.03
  • Accessories: sm3000+eth 5 port to get SI on onix CT,
« Reply #3 on: February 20, 2022, 10:06:01 AM »
If no grommet fits , marine silicone or sealer can do a good job . some are removable when needed .
Offline FishinLite
  • Software: 7.765
« Reply #4 on: February 21, 2022, 11:01:01 AM »
Last post May 07, 2012, 06:04:28 PM
by depark1
Last post May 16, 2013, 09:15:37 PM
by Rotus623
