Author Topic: 898c SI voltage reading (low)  (Read 17130 times)
Offline snopro67
  • Unit(s): 898cSI
  • Software: 5
  • Accessories: none
« on: June 26, 2011, 09:50:23 PM »
my unit seems to read about .4 VDC lower than the actual voltage. Anyone else have this issue? This almost caused me to buy a new battery.
It is connected to the battery with 16 guage wire with nothing else running on it.
16' Walleye boat. I have firmware version 5.500
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: 898c SI voltage reading (low)
« Reply #1 on: June 26, 2011, 10:26:27 PM »
Your unit will run on 10-20 volts.What meter gauge etc. do you go by. Run till it
quits working. Gary
Offline snopro67
  • Unit(s): 898cSI
  • Software: 5
  • Accessories: none
« Reply #2 on: June 26, 2011, 10:50:44 PM »
Gary,
I realize the unit will stay running. I use this voltage reading to gauge my battery "stage of charge"
A battery reading 12.3 volts with say just the running lights on would indicate a good battery charge. But my unit would read 11.9 volts indicating a possible problem.
Offline stillbear
  • Stillbear
« Reply #3 on: June 27, 2011, 07:00:31 AM »
Snop67 That reading difference you are talking about is a reading with and without resistance
your unit has resistance and is showing a different voltage. Which is normal. I check my
battery with a hydrometer then if the cells are all pretty equal I can load test it if I want.
Offline snopro67
  • Unit(s): 898cSI
  • Software: 5
  • Accessories: none
« Reply #4 on: June 27, 2011, 07:01:05 PM »
Gary,
All I can say is this "resistance" effect doesn't seem to affect my $200.00 Humminbird 565 near to the same extent. I understand I won't have the exact reading I do at the battery because the wire has resistance in it, the farther from the wire the more resistance. But a .4 to .5 VDC error seems excessive. Especially when I can check the voltage at the fuseholder which is soldered at the end of the Humminbird wiring harness. I get a .35 VDC error there. I emailed Humminbird to see what they say
Offline Del
  • Unit(s): 1197 SI
« Reply #5 on: June 28, 2011, 02:54:01 AM »
Well, your $200 565 has a smaller screen and a differten transducer, the power consumption should be less than on your 989. Higher power consumption would result in higher resitance and a lower voltage level. If i'm putting on full nav-lights on my boat my main battery's voltage drops from 12,6 to 12,1. I would assume you to check your voltage level with a voltmeter, when your 989 is powered on and off to check the difference.
Greetings,
Del
Offline stillbear
  • Stillbear
« Reply #6 on: June 28, 2011, 06:25:24 AM »
It is connected to the battery with 16 gauge wire with nothing else running on it.
Del checking  or replacing a battery because of what a voltmeter says is proably the
worst thing you could do.If your unit reads around 12 volts give or take a few points when
your trolling and around 13 volts or more when you start your big motor you are good to go.
« Last Edit: June 28, 2011, 06:26:54 AM by stillbear »
Offline edwardpic
  • Just fish....No excuses
    • My Company
  • Unit(s): 898c and 1198c
  • Software: 5.500 and 5.500
« Reply #7 on: June 28, 2011, 10:36:07 AM »
I have found on my boat even the digital battery gauge is off just a little....I use a battery tester I have here at my shop for a true battery test....I have a gauge cluster that all 3 of my batteries have their own gauge, but, at the same time I have a 20 watt solar panel attached to my T-top and charges the battery used for livewell-electronics and radios all the time, it has a charging regulator wired in between....
Big E
Offline Del
  • Unit(s): 1197 SI
« Reply #8 on: June 28, 2011, 12:39:26 PM »
That's not been me!  ??? ???  ;)
Theres really no reason to worry about lower voltage readings while the unit is powered on. I tested just the same with my 1197 and i had a 0.4 drop, too.
edit; no problem stillbear  ;D
« Last Edit: June 28, 2011, 02:38:03 PM by Del »
Offline stillbear
  • Stillbear
« Reply #9 on: June 28, 2011, 02:15:17 PM »
Sorry Del I meant snopro 67
Last post December 23, 2010, 06:31:22 PM
Last post March 04, 2011, 11:35:32 PM
by ferney69
Last post January 02, 2012, 01:46:33 PM
by xSilmarilSx
Low Voltage
Started by spes 798c SI
Last post January 27, 2013, 03:23:36 PM
by strawdg
Last post April 09, 2013, 10:40:21 AM
by jepik
Last post April 18, 2013, 03:53:24 PM
by Rotus623
Last post March 24, 2014, 03:13:28 PM
Last post August 12, 2014, 12:30:15 PM
