Author Topic: Ethernet plug as a waterproof cover  (Read 19005 times)
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
« on: May 06, 2012, 07:18:55 PM »
I have ordered a 20' ethernet cable for my 998 that I am going to cut one end off and install a cat5 plug on it so I can connect to my laptop for use with Dr. Depth.  My question is are there any reasons that I couldn't use the cut off connector as a waterproof cover for the ethernet port on the back of the 998 by sealing the cut wires with liquid tape and shrink tubing?  That way the connector would be protected when not in use.  I just thought I would ask if anyone else has done this in the past.
Darryl
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: Ethernet plug as a waterproof cover
« Reply #1 on: May 06, 2012, 10:42:05 PM »
The connector on the unit body is already waterproof, even when noting is put in them.
It will keep the debris off in you want. But I don't think is necessary.
Offline Rüdiger
« Reply #2 on: May 07, 2012, 02:57:26 AM »
Hi Darryl
I've also made ​​a cable, to the tightness of the need RJ45 (Cat5) connectors do not you care, unless you have a waterproof laptop.
mvh
Rüdiger
Finding is better than losing
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
« Reply #3 on: May 07, 2012, 06:04:28 PM »
I don't plan on using the Ethernet all the time.  I just figure that it can't hurt.
Last post February 18, 2011, 05:23:39 PM
Last post May 06, 2011, 10:36:41 PM
by Fishfinger
Last post July 11, 2012, 06:20:16 PM
Last post January 05, 2013, 03:56:14 PM
by Patty
Last post May 16, 2013, 09:15:37 PM
by Rotus623
Last post August 22, 2014, 12:14:58 PM
by waggman
Last post May 18, 2015, 10:58:06 PM
Last post February 21, 2022, 11:01:01 AM
by FishinLite
