Author Topic: In Line Fuse needed?  (Read 10899 times)
Offline EZM
  • Unit(s): ONIX 10 SI, 898c HD SI,858c (x2), 688ICE
  • Software: vX.XXX and v6.570
  • Accessories: Terrova i-Pilot Link, 5 port Ethernet
« on: February 23, 2013, 01:21:04 PM »
If I'm running a dedicated fuse block, with a dedicated 10 gauge electrical line up from the cranking battery, for my electronics (3 head units and an Ethernet port) each with it's own 3 amp fuse off the block, will I need to also install a inline fuse at or near the battery?
If so how many amps should this added in-line fuse be?
What style or type is best?
Thank-you, in advance for any information.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: In Line Fuse needed?
« Reply #1 on: February 23, 2013, 04:15:06 PM »
No inline fuse needed. The fuse block takes care of that bit for the unit. There should be a breaker near the battery for that fuse block though.
Offline EZM
« Reply #2 on: February 25, 2013, 12:07:34 AM »
What size, style breaker you think might be best. There seems to be million choices out there ......ugggg!!!!
Offline LocDown
    • Fishing Videos
« Reply #3 on: February 25, 2013, 01:18:36 AM »
Depending on how many things are connected to the fuse block. I would think a 50/60 amp breaker switch should be good. You can get something that you can break the circuit if you're worried about battery drain.
« Last Edit: February 25, 2013, 01:20:10 AM by LocDown »
« Reply #4 on: February 25, 2013, 12:13:22 PM »
I wouldn’t think that you need anything that large.  With three units plus the Ethernet Switch you should not have a current draw of more than 4 amps.  There is sometimes an initial start-up current surge so even if you managed to turn them all on at the same time you would not be pulling over eight amps.  I would look for a 10 amp breaker or just install an in-line fuse.
Offline Ken L
  • Unit(s): 598C HD DI-SI
  • Software: 6.460
  • Accessories: none
« Reply #5 on: February 25, 2013, 01:15:57 PM »
I would bet that long before a 60 amp breaker tripped you would smell a problem. I assume the cranking battery is hooked up to an onboard charger and even at that a long day with that many devices could not only draw it down too low but shorten its life at the same time.
Offline LocDown
    • Fishing Videos
« Reply #6 on: February 25, 2013, 07:11:45 PM »
oops, I didn't see the dedicated fuse block part. :)
Last post March 21, 2010, 01:22:53 PM
Last post April 26, 2010, 08:54:10 PM
Last post November 18, 2011, 06:11:48 PM
by carlg
Last post December 05, 2011, 04:54:38 PM
Last post March 26, 2012, 09:11:45 AM
Last post February 25, 2013, 01:24:17 PM
by Ken L
Last post November 04, 2014, 07:30:03 AM
by mudkart
Last post December 16, 2016, 12:58:09 PM
by N9Phil
