Author Topic: in line fuse  (Read 11972 times)
Offline rexico
  • Unit(s): 798 si combo --597 GPS
in line fuse
« on: March 26, 2012, 08:24:25 AM »
what size inline fuse would you use for power to the console  in my skeeter 190
Re: in line fuse
« Reply #1 on: March 26, 2012, 08:26:16 AM »
You didn't specify what to power.
Assuming you are referring to a Humminbird sonar,
then it's 3 amp.
Offline rexico
Re: in line fuse
« Reply #2 on: March 26, 2012, 08:40:37 AM »
I have two circuit breakers on the battery post which take up to much room I can bearly get the screw on ...I am talking about the main power source to the whole console  you know lights, livewell, and whatever when  i connected my bird this issue came up
Rex
Re: in line fuse
« Reply #3 on: March 26, 2012, 09:11:45 AM »
If that's the case, then I would recommend you first find out the
amp draw of each individual electrical device that will be run
from your console, and total them all up.
Then maybe give yourself a 50 percent safety margin.
So, take the total you added up times 1.50, should give you the
maximum amp fuse you should use.
Also, you have to consider if you have a big motor wired into your console.
Those things will draw a lot of amps when cranking.
I'm no expert, this is just my opinion.
Other opinions may vary.
Maybe wait for others to chime in.
The main reason why inline fuses are used is because if an electrical
device malfunctions and starts to pull lots of amps, rather than have
melted wires and/or a fire, the fuse will blow first, which will prevent
any other current to flow.
« Last Edit: March 26, 2012, 09:14:51 AM by ITGEEK »
Last post March 21, 2010, 01:22:53 PM
Last post December 05, 2011, 04:54:38 PM
Last post February 25, 2013, 01:24:17 PM
by Ken L
Last post February 25, 2013, 07:11:45 PM
by LocDown
Last post April 01, 2013, 02:36:57 PM
by hchelette
Last post May 09, 2013, 09:45:26 PM
by promapper
Last post November 04, 2014, 07:30:03 AM
by mudkart
Last post December 16, 2016, 12:58:09 PM
by N9Phil
