Author Topic: Blowing fuse  (Read 6884 times)
Offline flabob
  • Unit(s): Solix 10 SI G2
Blowing fuse
« on: December 16, 2016, 11:06:56 AM »
I wired my unit into the main bus . When I turn on my other GPS unit (Standard Horz.) the Helix 7 brakes up and dims. Because of the interference I was told to run the wires directly to the battery with a inline fuse.  I hooked it up to the battery switch and engine ground. Now when I have my Helix7 on and start the engine it blows the fuse inline with the Helix. Does anyone know why or what I'm doing wrong?
Offline N9Phil
Re: Blowing fuse
« Reply #1 on: December 16, 2016, 12:58:09 PM »
Your Helix ground should be hooked directly to the Negative Battery Terminal not any place else.  It is a pure guess but I would think that when you start your motor you are getting a current spike thru your Helix causing the fuse to blow.
Last post March 21, 2010, 01:22:53 PM
Last post March 26, 2012, 09:11:45 AM
Last post February 25, 2013, 01:24:17 PM
by Ken L
Last post February 25, 2013, 07:11:45 PM
by LocDown
