Author Topic: Are Two Transducers Possible?  (Read 14498 times)
Offline spes
« on: December 02, 2012, 04:58:58 PM »
Hello.
I am thinking of getting either a 598 or a 597.
I would like to have a transducer on the transom when I am under power and be able to switch to a transducer mounted to trolling motor when I am hunting.
Is that possible? Some kind of switch to switch between the two transducers?
Thanks,
Offline Roddy
  • Scan,scan and rescan
Re: Are Two Transducers Possible?
« Reply #1 on: December 02, 2012, 06:05:36 PM »
spes, Yes it is done all the time.
All that is needed is the right switch for the unit frome Humminbird.
Roddy
Scan,Scan and Rescan Roddy
Offline spes
« Reply #3 on: December 05, 2012, 07:58:14 PM »
Thank you for the replies..
If I got a 598ci HD SI Combo unit
would a XTM 9 SI 180 T Transducer Trolling Motor Mount Transducer be the correct transducer?
The 598 isn't listed on any trolling mount units... so i'm guessing on this.
« Reply #4 on: December 06, 2012, 08:11:56 AM »
spes:
It's weird.  The transducer you mentioned (XTM 9 SI 180 T) is mentioned as the
standard transducer for the 598ci HD SI.
But, if you look at the specs for that transducer, it says:
For Use with
797c2 SI
798c SI
Maybe Humminbird needs to update their website.
Before you buy, I would call Humminbird Customer service, just
to be sure that you are getting things that are compatible:
1-800-633-1468
« Last Edit: December 06, 2012, 08:13:46 AM by ITGEEK »
« Reply #5 on: December 06, 2012, 11:36:25 AM »
The web site needs to be updated.
The XTM-9-Si-180-T transducer will work with the 598ci HD Si units.
Offline spes
« Reply #6 on: December 12, 2012, 08:40:45 PM »
Thank You,
One more question on the 598 if I can squeeze it in here without starting a new thread  >:D
Does the wiring harness on that have an output to connect to my DSC VHF radio,,, so when I hit the panic button my GPS info is transmitted?
I think it does....
Thanks,,
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #7 on: December 12, 2012, 11:24:25 PM »
I think you will probably need the AS-HHGPS cable and enable NMEA output on the 598 and that should be it, after connecting the black and green wire to the VHF radio.
« Reply #8 on: December 13, 2012, 11:14:10 AM »
He would need the AS-HHGPS cable LocDown because the 598ci HD Si unit has an internal GPS Receiver, but the correct connections would be the White and Black wires.  White being the NMEA Output (or NMEA +) and the Black being the NMEA Ground (NMEA -).  He would also need to make sure that the NMEA Output menu was turned on.
Last post February 23, 2010, 11:36:06 AM
Last post September 15, 2012, 07:43:00 PM
by Justins
Last post February 06, 2013, 01:27:24 PM
by didier74
Last post March 26, 2013, 04:15:52 AM
by Gator
Last post March 09, 2014, 09:19:38 AM
by bobcoy
Last post May 14, 2014, 03:09:53 PM
Last post April 22, 2014, 11:05:31 AM
by Kevin Kromrey
Last post November 05, 2014, 01:59:52 PM
by dae06
