Author Topic: Using 2 transducers on my 798ci- Lowrance thru hull and humminbird transducers  (Read 6101 times)
Offline dae06
  • Unit(s): 798c SI Combo NVB
I bought a Ranger boat with a Lowrance thru hull transducer, is there a way to connect my Humminbird 798 to 2 different transducers? One would be the Lowrance thru hull transducer for high speed 2D sonar and the second one for the supplied 798 transducer for when this transducer is in the water. Apparently Ranger boats (1860VS) don’t have a good place to mount external transducers for when driving on plane so they need to be mounted higher up, but when not on plane the transducer is in the water. I am thinking the AS-SIDB-Y cable from the humminbird and an adaptor to the Lowrance transducer (Motorguide Tour Series Sonar Ready Humminbird 7-Pin Sonar Adapter) and the other part of the "Y" to the 798's transducer. Do you think this will this work?
Humminbird 798c SI Combo NVB
Last post April 05, 2012, 03:05:04 PM
Last post July 14, 2012, 11:04:09 PM
by stevemc
Last post September 02, 2013, 04:39:29 PM
by DiveExplorer
Last post September 13, 2012, 10:02:06 AM
Last post November 23, 2012, 09:53:47 PM
by BCLII
Last post March 26, 2013, 04:15:52 AM
by Gator
Last post November 19, 2013, 09:41:16 AM
by 220BayFox
Last post September 17, 2014, 11:42:07 PM
by theoryofwi
