Author Topic: 998c si and 798ci HD si with 3 transducers  (Read 12593 times)
Offline Gator
    • Crappie Club Page
  • Unit(s): 1198 c si, (2)998c si, 798ci HD si
  • Software: top secret
  • Accessories: ethernet, weather sence, I Pilot Link
« on: March 23, 2013, 04:52:03 PM »
Ok guys I've linked it all together... Heres what I got... I have a 798ci HD si (software vers. 6.610) on my bow hooked to my terrova US2 transducer. It is ethernet connected to my 998c si (software vers. 6.600) on my console. which is connected to two transducers (using a AS SIDB Y) a... XHS 9 HDSI 180 T and a... XNT 9 20 T. Hers the problem...
  1) the only two options I have on the 798 for transducer select  is compact si and quad beam. (on the network tab i can view the 998 transducer) since I'm using the US2 in the terrova shouldn't i have the option of a dual beam transducer???
  2) this is more a question than a problem... on the 998 will i have to swith back and forth between the two transducer when i change views (ie.. side image, Down image, and 2d) or does the "y" cable seperate the two and does it internally????
As always thanks for the help!!!
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: 998c si and 798ci HD si with 3 transducers
« Reply #1 on: March 23, 2013, 08:14:07 PM »
1) It's not recommended to connect your SI unit to the US2 transducer.
2) The Y cable grabs 2 different transducer information but the unit will only see one set. The XNT920T transducer will be solely for 2d imaging and the HDSI transducer will show the SI,DI, and temperature.
Offline Gator
    • Crappie Club Page
« Reply #2 on: March 23, 2013, 10:10:17 PM »
1) the reason I bought the 798ci si unit was to mount on bow and use with US2 transducer. While using transom mounted si transducer through Ethernet. This was what Humminbird Greg told me I needed to do.
2) ok, on my menu what transducer do I select... High def. SI ?
Offline Gator
    • Crappie Club Page
« Reply #3 on: March 23, 2013, 10:20:04 PM »
This is a quote from Humminbird website on 6.610 software upgrade...." • Removed Universal Sonar II transducer selection option, now users should select dual beam as their selection."
Why would they say that if you can't use US2 transducer. Problem I having is my 798 is not giving me the dual beam option.
Offline Gator
    • Crappie Club Page
« Reply #4 on: March 24, 2013, 04:06:38 PM »
Offline LocDown
    • Fishing Videos
« Reply #5 on: March 24, 2013, 05:17:42 PM »
Why don't you try to downgrade the firmware and see if it will show up.
Offline gixxer01
  • Unit(s): 798ci HD SI
« Reply #6 on: March 25, 2013, 11:28:57 PM »
The problem arose in v. 6.57. You would have to go back to 6.25 to get your Universal Sonar option back.  They never put a Dual Beam option in the ducer select menu (almost all other units have it).  We'be been instructed to useQuad Beam, as it should work the same.
http://forums.sideimagingsoft.com/index.php?topic=4962.0
Click the Link.
Offline Gator
    • Crappie Club Page
« Reply #7 on: March 26, 2013, 04:15:52 AM »
I talked to Jennifer at Humminbird gift and that's what she said. Use quad beam.
Last post April 05, 2012, 03:05:04 PM
Last post July 11, 2012, 04:54:29 PM
by Speedtroller
Last post December 15, 2012, 12:10:23 PM
by Jim Jack
Last post July 13, 2013, 09:50:07 AM
by werethefugowee
Last post August 02, 2013, 01:03:46 PM
Last post June 27, 2014, 10:26:23 PM
by ice
Last post November 05, 2014, 01:59:52 PM
by dae06
Last post October 25, 2019, 11:54:58 AM
by ezfishn
