Author Topic: Ethernet and two si transducers.  (Read 6703 times)
Offline ranger618
  • Unit(s): 797c, 898HD
« on: March 08, 2014, 11:58:18 PM »
I just bought an 898 to go with an i-pilot link.
I am thinking about getting another one so I can have one up front and one by the tiller.
I also plan to connect the i-pilot and both units through a 5 port Ethernet switch.
My question is. If I connect a transom mounted si transducer to the rear unit and a trolling motor mounted si transducer to the front unit, will i be able to use either transducer from either unit ?
Will I only be able to use the transducer connected to the unit ?
Will it not work correctly because the units will try to use both transducers at once ?
Thanks.
Offline Trout Bum
  • Unit(s): 958 HD, 788 ci HD
  • Software: 6.640
  • Accessories: aux speed & temp, ethernet
Re: Ethernet and two si transducers.
« Reply #1 on: March 09, 2014, 08:58:53 AM »
If you are connected by Ethernet you should be able to use either transducer with eiither graph.
You can choose which transducer, GPS puck, etc. to use with a specific graph by going to the Networking settings screen on each graph and making the selection.
2013 Lund Rebel 1650 XL Sport
60 hp Mercury 4-stroke
Humminbird 998c HD SI, 958c HD & 788ci HD
Minn Kota Terrova w/i-pilot
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #2 on: March 09, 2014, 09:19:38 AM »
Ranger, If you download the ethernet manual. Or use the manual on the dvd that comes with the unit. It expains all the questions I had about what is shared and what is not. Bob
Last post June 10, 2010, 05:42:51 PM
Last post February 12, 2012, 12:01:43 PM
by Fay
Last post July 19, 2012, 12:20:10 PM
Last post September 15, 2012, 07:43:00 PM
by Justins
Last post December 13, 2012, 11:14:10 AM
Last post February 06, 2013, 01:27:24 PM
by didier74
Last post April 15, 2013, 12:34:06 PM
Last post May 09, 2013, 03:05:54 PM
by EZM
