Author Topic: different between transducers  (Read 11331 times)
Offline river life
  • Unit(s): 798 ci hd combo
  • Software: 5.840
  • Accessories: none
« on: July 18, 2012, 08:31:04 PM »
i have the 798ci hd si combo . what is the dirrerent between the xnt 9 si 180 t and the xhs 9 hdsi 180 . it looks like have the xnt 9 si 180 t. i have looked up on the two but i like for someone to explain it to me. it looks like my transducer is not hd, but i have a hd unit. does this mean i need to upgrade or i didn't get the right transducer? when i purchased the unit i didn't receive the transducer mount, but humminbird sent me at no charge(thank you). i want to get the best out of my unit as i can. any and all advice would be great.
Offline Roddy
  • Scan,scan and rescan
Re: different between transducers
« Reply #1 on: July 19, 2012, 10:09:30 AM »
river life, start at the plug end of the transducer cable and look for a yellow mark on the yellow mark note the type of transducer it is.
Roddy
Scan,Scan and Rescan Roddy
« Reply #2 on: July 19, 2012, 11:15:31 AM »
XHS 9 HDSI 180 T Transom Mount Transducer
Dual/HD Side Imaging Transom, 20/60/86/55 Degree, 200/83/455/800 kHz with built in temperature. 20' cable
FOR USE WITH
•   1198c SI Combo
•   1197c si Combo
•   997c SI Combo
•   998c SI
•   898c SI
•   797c2 SI Combo (800kHz not active)
•   798c SI Combo (800kHz not active)
•   798ci HD SI Combo (800 kHz not active)
XNT 9 SI 180 T Transom Mount Transducer
Compact Dual/Side Imaging. 20/60/86 (2) degree, 200/83/455 kHz with built-in temperature. 20' Cable. More secure, especially at high force of waves. Improved running angle and an optional lock down screw to override the kick up.
FOR USE WITH
•   797c2 SI Combo
•   798c SI Combo
•   798ci SI Combo
•   798ci HD SI Combo
« Reply #3 on: July 19, 2012, 12:20:10 PM »
river life,
The XNT-9-Si-180-T (CSi) transducer is the correct transducer for the 798ci HD Si unit although the XHS-9-HDSi-180-T (HDSi) can be used in its place.
Basically the difference is that the HDSi transducer uses a longer set of Si elements inside of it that allow for more detailed 455kHz Si sonar as well as allowing it to work at 800kHz.  The CSi transducer uses shorter Si elements so it’s 455kHz Si sonar has less detail and cannot produce the 800kHz.  No problem though because your 798ci HD Si unit cannot produce the 800kHz sonar either.  Connecting your 798ci HD Si unit up to an HDSi transducer would not allow it to use the 800kHz Si sonar but it would have better detail in the 455kHz Si sonar – though some people cannot see this difference on the smaller display of the 798 units.
The “HD” designation for the 798 units was to denote that they are using a best-in-class display.  No one else is using a five inch display that has as many pixels.  It is also an easier way for us to know that you have a unit that has an Ethernet connection.
The “HD” designation for the XHS-9-HDSi-180-T transducer was used to denote that it used a higher definition frequency set for the Si sonar than did the first generation XHS-9-Si-160-T transducer that we produced.
Last post February 23, 2010, 11:36:06 AM
Last post April 05, 2010, 11:00:29 PM
by blharr4400
Last post June 10, 2010, 05:42:51 PM
Last post January 24, 2011, 03:59:01 PM
by Kennyscott
Last post February 12, 2012, 12:01:43 PM
by Fay
Last post March 21, 2012, 06:50:53 AM
by ksc
Last post September 02, 2013, 04:39:29 PM
by DiveExplorer
Last post November 05, 2014, 01:59:52 PM
by dae06
