Author Topic: 2 transducers for better images ?  (Read 7600 times)
Offline ksc
« on: March 10, 2012, 06:38:02 AM »
Hi everyone
It s told me that if i use 2 pisces of XHS 9 HDSI 180 T, my 998 csi gives me better images! anyone knows if it is true? if it s true, how long range should i left among these 2 transducers?
Thanks alot
Offline Rickard
Re: 2 transducers for better images ?
« Reply #1 on: March 10, 2012, 09:26:41 AM »
Hi ksc!
That's true you can get better horizontal resolution with a longer array. I and SeaRover have constructed such arrays by joining two SI transducers. SeaRover has built entirely new arrays by picking out the elements from two transducers and mounting them in new housings. You can't just line up two transducers because the elements are not allowed to be farther apart than 1/4 of a wavelength. This is about 1 mm at 455 kHz. The transducer housings must be modified by cutting/grinding away material so the SI elements can be positioned no more than a mm apart. The details in these projects are discussed here: http://forums.sideimagingsoft.com/index.php?topic=363.0
Kind regards,
Rickard
Offline Rüdiger
« Reply #2 on: March 11, 2012, 08:52:11 AM »
Hi ksc :D
Do you mean two transducer, one each right and left?
This constellation is expected to bring a better result, thus will make sense if there are no other suitable mounting option.
mvh
Rüdiger
Finding is better than losing
Offline ksc
« Reply #3 on: March 21, 2012, 06:50:53 AM »
Thank you so much for your help. This answers made me happy..
Last post February 23, 2010, 11:36:06 AM
Last post March 16, 2010, 06:08:28 PM
Last post April 05, 2010, 11:00:29 PM
by blharr4400
Last post June 10, 2010, 05:42:51 PM
Last post January 24, 2011, 03:59:01 PM
by Kennyscott
Last post April 15, 2011, 08:14:21 AM
by FlatsFokker
Last post February 12, 2012, 12:01:43 PM
by Fay
Last post March 23, 2012, 12:13:59 PM
by Gattlin
