Author Topic: Dual Transducers  (Read 10980 times)
Offline Kennyscott
  • Software: Pinnacle
Dual Transducers
« on: January 24, 2011, 09:54:54 AM »
Is it possible to run two tansducers from one fish finder. One at a time ..example, one connected to the transom then another on a pull behind towfish.  My thought is to use the transom mount tranducer to spot something of interest then swing around with the towfish to get a closer more detailed look. I know I could plug and unplug the wires, but is there a switch that could be used to change from one to the other. I saw the switches on on the site but says they are for using one transducer to change between two fish finders.
Re: Dual Transducers
« Reply #1 on: January 24, 2011, 09:58:58 AM »
There is a US2W and a TS2W.  The TSW2 is a transducer switch that will do exactly what you are looking for!
http://store.humminbird.com/products/322973/TS2_W
Good Luck,
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #2 on: January 24, 2011, 02:23:06 PM »
Hi Kenny,
like Robert adviced, I have the same set up with the transducer switch.
It works perfect when I have the fish deployed.
I heard that there will be a new switch be coming out. Don't know what this is all about. Maybe a different design with a stronger spring. Mine seems a bit limp.
Best wishes / Harry
YES,......
WE SCAN!
Offline Kennyscott
« Reply #3 on: January 24, 2011, 03:59:01 PM »
I think that would be a great feature to have added to the upper end fish finders. Push buton...In for transducer "A" out for "B".
Kenny
Last post March 16, 2010, 06:08:28 PM
Last post April 05, 2010, 11:00:29 PM
by blharr4400
Last post June 10, 2010, 05:42:51 PM
Last post January 03, 2011, 01:12:25 PM
by keizerh
Last post July 22, 2011, 11:21:09 PM
by stratofisher
Last post April 23, 2012, 01:11:57 PM
Last post September 15, 2014, 01:07:28 PM
Last post December 06, 2016, 09:17:49 AM
by trogersIII
