Author Topic: Views Flashing  (Read 8832 times)
Offline 6speedy3
  • Unit(s): 788ci;998si
Views Flashing
« on: April 23, 2012, 08:31:44 AM »
I was out for the first time yesterday. I noticed that when I was scrolling through the Views. The screen was flashing when I switched between the Chart/Side Imaging View and the Down Imaging/Side Imaging View. It did when I hit the exit button to back up as well. Hit the button a second time and it straightened out. Any one experience this. I am just starting to learn this 998 and I love it other than that. Suggestions?
I  have not put the 6.180 upgrade in yet. Thanks
Re: Views Flashing
« Reply #1 on: April 23, 2012, 08:56:58 AM »
You might want to check all of your connections to be
sure they are good and tight.
You could have some vibrations that are loosening things up.
It also wouldn't hurt to charge up your battery and load test it.
Good Luck.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Views Flashing
« Reply #2 on: April 24, 2012, 12:44:04 AM »
 6speedy3
     I had a similar problem with my 998. The DI screen would flash when that page was displayed either by View/Exit or preset #2.
     At the same time the quality of the SI display on the unit went to unreadable.( deep or shallow ).  2D was fine.
     Returned unit, including transducer, to HB ($40.00 shipping and insurance ). Report-- No problem found-- updated software to 6.18. $65.00-- thank you.
     Since the units return I've recorded about 5 hours-- so far, so good.
Offline 6speedy3
Re: Views Flashing
« Reply #3 on: April 24, 2012, 08:23:33 AM »
I updated to 6.18 yesterday and it seems to have solved it. I haven't been on the water yet but doesn't flash in the garage.  :)
Last post February 16, 2011, 02:57:38 PM
Last post September 26, 2011, 11:27:01 AM
Last post July 23, 2014, 07:39:48 AM
Last post January 17, 2016, 09:38:56 AM
by larry crouch
Last post June 14, 2016, 10:50:58 AM
by D S
Last post June 06, 2017, 10:40:03 AM
by grizwilson
Last post August 01, 2017, 02:47:41 PM
by Moose1am
Last post March 15, 2024, 06:00:02 PM
by Bayou Basser
