Author Topic: 898 humminbird and programming map's with views and keeping mapping on as a sid  (Read 9504 times)
Offline larry crouch
  • Unit(s): 898c&586hd
  • Accessories: lakemaster and navionic
Im putting my map on and wanting to pair up with some of the views and the map is not coming up with the view's, as soon as I hit the preset button the maps are gone. I know I' m missing a step here but not sure which one. Thanks for you help. Larry.
The split views are not customizable ...
The available views (and split views) can be found under the "Views" tab in the main menu system ...
*Press Menu twice to enter the main tabbed menu ...
*Cursor over to the "Views" tab ...
*Cursor down and select "Visible" for any view (or split view) you want available when scrolling thru the views Rolodex  ...
To select a specific view (or split view) as a preset ... Press and hold the desired preset button for 3 seconds and the displayed view (or split view) will be set to that preset button ...
RNVINC:  Thanks for the information. I just got brain dead and could not remember the settings so I could just put certain views on but any way thanks for you help. Larry.
Delete it , thanks.
Last post September 26, 2011, 11:27:01 AM
Last post April 24, 2012, 08:45:14 AM
Last post April 24, 2012, 08:23:33 AM
by 6speedy3
Last post May 13, 2012, 03:18:10 PM
by Turk
Started by Fay 798c SI
Last post June 16, 2012, 09:22:42 AM
by Fay
Last post May 06, 2013, 03:56:01 PM
Last post December 01, 2013, 08:36:04 PM
by Moose1am
Last post January 30, 2015, 01:58:07 PM
