Author Topic: Views don't work correctly with 360 and 1198  (Read 7566 times)
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Software: Latest Versions
« on: July 22, 2014, 10:17:09 PM »
I am going to post a few anomalies that I have found with the software relating to the 360.   I doubt that Humminbird will have the resources to fix minor issues like these.   Maybe this will help someone else who has the same problem.
I have an 1198 running version 7.09 at the bow and I have a 360 trolling motor mount running version 2.03 - both units running the latest software downloaded from Humminbird.com.  This issue has also happened with previous versions of the software since I purchased the 360 last December.  I always update to the most current versions.
Issue #1:  When I power up the 1198 and give the 360 imaging time to come up, I expect to see the following views, in order:  360, 2D/360 combo, Map/360 combo.   However, the 2D/360 combo box doesn't appear.   To get it to appear, I have to turn off the sonar, then turn it right back on.   The 2D/360 view now appears.
If I turn on the 1198 with sonar set to OFF and later turn it ON, the 2D/360 view appears.
Issue #2:  When the 360 is on, sometimes the Map/360 combo box disappears.   I have to reboot the unit to get it to reappear.
Re: Views don't work correctly with 360 and 1198
« Reply #1 on: July 23, 2014, 07:39:48 AM »
I would report these issues to Humminbird customer support.
They may fix them in a future update.
Last post July 23, 2012, 07:15:10 PM
by jexeri
Last post January 14, 2013, 12:14:16 AM
by coriobay
Last post July 06, 2013, 01:01:51 PM
by theflatlander
Last post August 20, 2013, 06:52:43 PM
by pingman
Last post March 25, 2014, 11:41:28 AM
Last post April 30, 2014, 03:08:02 PM
by tdclaymc16
Last post July 07, 2015, 06:17:42 PM
by jessie33
Last post May 26, 2016, 10:43:43 AM
by Bill H
