Author Topic: Down loading waypoints from SD card to 788ci hd  (Read 12494 times)
Offline cfleague
  • Unit(s): 898c
  • Software: 6.18
« on: April 16, 2012, 08:30:16 PM »
I have down loading(export) my waypoints from my 898si onto a SD card. I put it in
my 788ci hd unit but can't figure out how to load it into my unit. I can see all the waypoints
with card in the SD slot but want to down load it onto my unit and take chip out.
Re: Down loading waypoints from SD card to 788ci hd
« Reply #1 on: April 17, 2012, 12:23:33 PM »
When you installed that SD card into your 788ci HD unit it should have given you a message that it was loading XX number of waypoints.  If you are seeing the waypoints on your 788ci HD unit than they have already been loaded into it.
Offline cfleague
  • Unit(s): 898c
  • Software: 6.18
« Reply #2 on: April 20, 2012, 08:41:33 PM »
Hi Greg,
Still having problems loading waypoints from sd card onto my 788cd hd. I tried this
twice thinking I may have messed things up. I put my sd card into my 898 si and asks me
if i want to load waypoints etc. on to card and hit the yes button. Takes all of about
1 second(120 waypoints). I then put it into my 788 and turn on unit. It doesn't ask me
any questions about downloading waypoints on unit, just starts showing normal operation.
The reason I seen the waypoints before is I had in interlinked from 898. My sd card has
Matrix and profile on it after exporting from 898 to sd card. Any help?
Thanks,
Dave
Offline wolfs4evr
« Reply #3 on: April 20, 2012, 09:39:40 PM »
If it isn't alerting you with the "do you want to..." type of thing try this.  Turn the unit on then insert the card.  What I have to do on my 898 with the newest update to get it to give me that pop up/option.
Offline cfleague
  • Unit(s): 898c
  • Software: 6.18
« Reply #4 on: April 22, 2012, 08:31:25 PM »
Thanks wolfs4ever! that solved my problem
Last post April 29, 2010, 09:21:23 AM
by kskloss
Last post November 09, 2010, 06:47:58 PM
by FuzzyGrub
Last post February 19, 2011, 06:31:01 AM
by stillbear
Last post October 18, 2011, 07:32:58 AM
Last post July 13, 2018, 01:08:00 AM
Last post March 12, 2013, 11:58:26 AM
Last post August 11, 2012, 03:27:19 PM
by dubosegriffin
Last post July 19, 2016, 01:18:01 PM
by Beaulieu80
