Author Topic: Transducer placement on a 1994 skeeter ZX 175 have a 798ci HD SI  (Read 12275 times)
Offline robbiec911
  • Unit(s): 798ci HD SI
I have a 1994 ZX 175 skeeter an I just bought a new hummingbird 798ci HD SI an I'm having trouble figuring out the best place to mount the transducer. It has a 6 inch hi-jacker plate on a marinar 175... If anyone has any feed back on this issue it would be a major help. Thanks guys!!!
Re: Transducer placement on a 1994 skeeter ZX 175 have a 798ci HD SI
« Reply #1 on: February 01, 2012, 12:36:12 PM »
Many are mounting the Si transducers on the jackplate and installing an XP-9-20 transducer inside-the-hull and an AS-Si-DB-Y cable.  This allows the Si transducers to be installed in a more protected location and an inside-the-hull transducer gives the best high-speed depth readings on fiberglass hulled boats.
« Reply #2 on: February 01, 2012, 12:46:25 PM »
When you make an inside the hull installation take care to ensure you epoxy without air bubbles. Mix carefully and apply carefuully.  Next scrape any existing paint or colored eposy from the inside of the hull to get rid of any bubble in the covering sand smoothe. Also when using the 9 20 make sure the hull is a single hull and not a layered hull as per the HB description. Again layered hulls can have an air space.  The 9 20 does not like this.  as with most sonar air is our enemy.
Chuyck
« Reply #3 on: February 02, 2012, 10:25:51 AM »
Make sure that you test the installation area per directions before you start mixing that epoxy up.  There have been many that have installed these in boats and not had them work because of the lack or testing or proper preparation of the installation area.  The transducer needs to be bonded to clean and solid fiberglass.
Last post June 27, 2010, 12:04:16 AM
by Brian37075
Last post August 09, 2012, 01:39:03 PM
Last post September 11, 2012, 05:01:42 PM
by Slinger
Last post December 30, 2013, 10:52:41 PM
Last post March 12, 2015, 10:26:15 AM
by BrazosRiverTom
Last post April 16, 2016, 10:09:41 PM
by fishnfool
Last post February 08, 2019, 10:21:59 AM
by bassmasterG13
