Author Topic: Which Map Card?  (Read 16846 times)
Offline rookiejd
  • Unit(s): 898,859, Terrova, I-pilot, Ethernet
  • Accessories: gps
Which Map Card?
« on: February 29, 2012, 09:28:24 PM »
I have a new 898c SI combo unit installed on my boat. I have had it out only once since getting it installed,pretty cool stuff. I want to use the unit in North Alabama for crappie fishing. I have two questions. I need to know what map card I should purchase and if that map card can be viewed on my pc.
Offline Roddy
  • Scan,scan and rescan
Re: Which Map Card?
« Reply #1 on: February 29, 2012, 11:25:54 PM »
The map card can not be used on a PC. There are three cards for Alabama, Two chart cards and a Fish'n chip card and a Lake Master card/disk. Roddy
« Last Edit: February 29, 2012, 11:30:02 PM by Roddy »
Scan,Scan and Rescan Roddy
Offline George
  • Software: Always up todate
Re: Which Map Card?
« Reply #2 on: March 01, 2012, 07:07:14 AM »
rookiejd
You may want to check LakeMaster's list to make sure it has your lake.
--->  http://www.lakemap.com/documents/lakelists/2012/HB_AFG1_LakeList.pdf  <----
LakeMaster still have away to go before their mapping programs are sorted out (in my opinion).  I recently purchased their Contour Elite only to be dissapointed with the softwares capability.
Also, Navionics has a premium S chip which covers a lot of states, again you may want to check the lake list.
--->  http://www.fugawi.com/web/products/navionics_regions/prem-s6_lakelist_2010.htm <---
The benefit for Navionics is that you can view the lakes on your computer via NavPlanner2, there is also Hotmaps Explorer.  This are you should spend some time investigating before deciding.  I have Fugawi Hotmaps Explorer a=with an HD map of my lake and I am very happy with it, it is an older system, not sure about the new systems.
George
George
Offline rookiejd
  • Accessories: gps
Re: Which Map Card?
« Reply #3 on: March 03, 2012, 08:10:36 AM »
Thanks for the help!
Offline papasage
  • Unit(s): 598 si di 3575 depth finder and one dow
  • Software: non
  • Accessories: non
Re: Which Map Card?
« Reply #4 on: June 20, 2017, 09:36:08 PM »
i just want to record my trips  with my si  will it and what card  should i get
Re: Which Map Card?
« Reply #5 on: June 20, 2017, 09:47:50 PM »
For Sonar recording any SD card or SDHC card less than 32gb can be used  ...
Class 10 (with high read/write speed) will handle file management better when manipulating the recording data from SD card to PC  ...
« Last Edit: June 20, 2017, 09:49:26 PM by rnvinc »
Last post April 19, 2012, 10:38:43 AM
by slabbandit
Last post September 09, 2013, 01:33:07 AM
by LocDown
Last post January 26, 2014, 11:27:05 PM
by Dieago
Last post April 07, 2014, 08:09:53 PM
by Saltykayak
Last post April 25, 2014, 05:09:35 PM
Last post May 29, 2014, 08:56:40 AM
Last post July 11, 2014, 06:11:00 AM
by mmikos
