Author Topic: Poor quality images lately...very grainy ...horizontal static..  (Read 13434 times)
Offline bwallis
  • Unit(s): 798ci
« on: September 05, 2011, 10:54:56 PM »
Last few times out I have been recording as usual. But lately my image quality has been really poor.  I'm not sure why.... I typically will run with factory default settings...I can make it better but in general, the defaults are good enough to find brushpiles, structure and fish.  it seems worse on playback with humviewer than it does playing back through the unit.  I have managed to hit some pretty good stumps and rocks a few times...but really nothing out of ordinary...My 'ducer did flip up awhile back when I drifted into a wingdam (whoops)....but I've done that before..I snapp'er back down and keep chuggin.
I did switch props earlier in summer...same size prop..went to Stainless from Aluminum....
Terrova TM w/ iPilot....
Here's a pic...That's a riprap wingdam to the right and flat clean bottom to left (Arkansas River at Little Rock)
Perplexed...I've had crisper images in past.  Thoughts?
Offline Roddy
  • Scan,scan and rescan
Re: Poor quality images lately...very grainy ...horizontal static..
« Reply #1 on: September 06, 2011, 02:49:07 AM »
5.8 mph is kind fast for good si/di shots. try 2 to 3 mph and repost. Good lick and enjoy Roddy :)
« Last Edit: September 06, 2011, 02:55:37 AM by Roddy »
Scan,Scan and Rescan Roddy
Offline bwallis
  • Unit(s): 798ci
« Reply #2 on: September 06, 2011, 12:12:39 PM »
Roddy, thanks for the reply. Here's another shot at slower speed.....
Offline SonarTRX
    • SonarTRX
  • Unit(s): 998c-SI
  • Software: SonarTRX
« Reply #3 on: September 06, 2011, 03:12:32 PM »
Hi bwallis,
It seems like your Humviewer images are very "washed out", with little details in the high-lights?
If so, you might want to select another Humviewer color model, or edit the green color model to get more details in the high-lights. (Experiment by sliding the green slider-bar up and down to see how it affects the appearance of the images)
If the same problem occur on your sonar display, as a work-around, try the same thing there; Use a SI Color palette that bring out more details in the highlights, and experiment with the other display settings.
If none of this brings out more details in the lighter areas, perhaps there are some issue with the sonar...
Tore
tore@sonartrx.com
http://www.sonartrx.com
« Last Edit: September 06, 2011, 03:19:34 PM by SonarTRX »
Offline Roddy
« Reply #4 on: September 06, 2011, 04:52:13 PM »
Bwallis; Some bate balls, lots of fish, some surface clutter try adjustmest for this. At a blow up of 800% SI shows a lot of beam area miss. could slow down boat speed to 2 to 3 mph.
Keep going over the same target and adjusting your unit till you are happy.
Scan Scan and Rescan. Good luck and enjoy!!!  Roddy
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
« Reply #5 on: September 08, 2011, 09:33:36 PM »
It looks like interferece to me.  Are you running the TM while you are recording? I get same stuff from my TM.
Last post October 12, 2009, 03:24:29 PM
by wizzo86
Last post May 11, 2011, 12:26:05 AM
by LocDown
Last post April 10, 2012, 08:36:22 PM
by coriobay
Last post April 03, 2013, 12:46:53 PM
Last post October 01, 2013, 08:37:12 PM
by silentkilla
Last post October 21, 2013, 10:35:12 AM
Last post December 25, 2013, 11:15:49 PM
by slabbacks
Last post April 05, 2014, 12:17:20 PM
by LittleGazoo
