Author Topic: SI- one left side is grainy  (Read 11807 times)
Offline Southbound
  • Unit(s): 898C SI
  • Accessories: non
« on: April 09, 2012, 06:35:47 PM »
 So I moved my trans down a little to see if I can pick up depth on a plane. didnt work.  My SI was working fine till I planed out went I came to idle the left side of the SI was very grainy..
Has this been an issue that yall have run into???
Thanks for all your help
Re: SI- one left side is grainy
« Reply #1 on: April 09, 2012, 07:39:56 PM »
Yep....about normal for si..
« Reply #2 on: April 10, 2012, 10:36:23 AM »
Southbound,
You should also try lowering the backend of your transducer downwards just a little bit and test it again to see if it helps or not.  Typically you have to get the transducer down below the level of air-mixed water that comes off the hull of the boat for it to read at higher boat speeds.  Alternately if you can do so without affecting the Si sonar: you can move the transducer backwards away from the boat by adding some sort of a spacer to get the transducer into cleaner air bubble-free water.
As for the left side Si being grainy: make sure that there is nothing now blocking the left Si sonar and make sure that the transducer is not twisted (has a clockwise twist when viewed from behind).  Other than that, unless you damaged the left side of the transducer you should be getting the same image quality off of it that you did before lowering the transducer.
Offline coriobay
  • Unit(s): 898csi
  • Software: 6.1
  • Accessories: none
« Reply #3 on: April 10, 2012, 08:36:22 PM »
My ducer has a habit of picking up leaves and blocking one side or both.
Last post June 06, 2011, 12:12:03 PM
Last post June 05, 2011, 09:21:26 PM
by Double Digit
Last post October 22, 2011, 07:01:20 PM
by jgollihar
Last post April 16, 2012, 10:48:52 PM
by Shooter00
Last post May 01, 2012, 02:22:26 AM
by Wylezalek
Last post March 14, 2013, 04:37:52 PM
by Rickard
Last post June 21, 2016, 11:33:31 AM
