Author Topic: static problem with 798 after interlink install  (Read 14236 times)
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« on: April 24, 2011, 11:26:44 PM »
is there a setting I can change to get my sonar readings clean again?
Before:
marion 20110416
After:
humminbird static
Offline FuzzyGrub
    • Joe Fish
  • Software: Latest
  • Accessories: TSW,
Re: static problem with 798 after interlink install
« Reply #1 on: April 25, 2011, 07:18:53 AM »
Did you have noise on both units?
Do you get the noise if other unit is off?   (is it interference?)
Do you get the noise as soon as you hook-up interlink?
Post how your system is configured.
Is everything powered from same battery?  If different batteries, are they grounded together?
JohnS
http://joefishin.com/
Offline LocDown
    • Fishing Videos
« Reply #2 on: April 25, 2011, 06:59:17 PM »
1. I just have noise on the 798
2. I have tried with the 778c on and off. It makes no difference.
3. Do you mean noise as if the boat is out of water and just powered on? I get a clean reading with the boat on the trailer(had the transducer in a bucket of water also to test). The 798 had clean sonar readings the day before on a different boat. It was just the unit and trolling motor transducer(different one).
798 is connected to  weathersense to choke to interlink head 1
778c is connected to 10ft+20ft cable to choke to interlink head 2
Both units are powered via starting battery.  798 is connected to a fuse box then to the battery. The 778c is connected directly to battery.
The 798 is on the console and the 778 is at the bow.
This is a center console type boat so before there was only the power/ground for the 778 running up front with the trolling motor tranducer. Now it also has the interlink cables running through the same routing tube and I have moved the trolling motor transducer to the rear as a shoot thru at the moment also in the same tube.
I will try other stuff next time out.. .might be a couple of weeks tho.
Offline FuzzyGrub
    • Joe Fish
  • Software: Latest
  • Accessories: TSW,
« Reply #3 on: April 27, 2011, 09:38:27 AM »
Isolating noise is a process of elimination.  You try to figure out what is generating the noise, and how it is getting into the electronics.   Start when you are on the water and experiencing the problem.  Shut the motor off, trolling motor, and then any other possible devices to figure out what is generating it.   Finding that will give clues to what wire routing etc, that might be changed.
Other things to try:
- Your units should be swapable.  Put the 798 on the bow and see if the noise follows.
- Swap interlink connections and see if the noise moves.
- Remove weather sense from the equation, etc.
JohnS
Offline LocDown
    • Fishing Videos
« Reply #4 on: May 03, 2011, 01:40:26 AM »
Ok, I was out today and had removed the interlink cable to the front unit and then tried with both finders on. No go. I shut the front finder off and the 798 screen cleaned up. So, now I will move the shoot through back to the trolling motor and try again with the interlink cable.
Offline FuzzyGrub
    • Joe Fish
  • Software: Latest
  • Accessories: TSW,
« Reply #5 on: May 03, 2011, 03:29:09 PM »
It sounds like you are getting sonar interferance.  How far apart are the two transducers and how deep of water were you in?
JohnS
Offline LocDown
    • Fishing Videos
« Reply #6 on: May 03, 2011, 09:52:33 PM »
the transducers were about 3ft apart. shoot-through and transom mounted. ...I am changing the shoot-through and putting on a trolling motor one.
« Reply #7 on: May 06, 2011, 01:48:04 PM »
If it only happens when both units are on; try turning on and up the Noise Filter menu in the unit showing the interference.
Offline LocDown
    • Fishing Videos
« Reply #8 on: May 07, 2011, 10:00:33 PM »
I have tried the noise filter and still no go.
Offline LocDown
    • Fishing Videos
« Reply #9 on: May 11, 2011, 12:26:05 AM »
will try again with shoot through disconnected and coiled up and interlink reconnected with trolling motor transducer connected. ...after I get the boat out of the shop.  The unit shows very good returns on my pond boat. .only thing is, my DI is never super clear. I have tried with chart speed 1 and 2, not as clean as I would like.
Last post January 26, 2011, 12:12:37 PM
by panman_va
Last post March 03, 2011, 02:44:11 PM
Last post April 01, 2011, 11:44:30 AM
Last post May 15, 2011, 04:01:32 PM
Last post August 10, 2011, 02:43:29 PM
Last post April 29, 2013, 01:52:19 PM
Last post February 12, 2014, 06:12:32 PM
by N9Phil
Last post June 23, 2014, 12:47:05 PM
