Author Topic: 1198c SI Horizontal lines  (Read 10089 times)
Offline connbass1
  • Unit(s): 1198C SI Combo
« on: April 04, 2014, 07:30:45 AM »
Looking for a little help. When I use my down image and the display speed is set to 2 I get horizontal lines (see pictures). I can eliminate them by  going into the DI Enhance and change the "sharpness" from high, medium, or low to the off setting. I can also eliminate them by using any setting other then 2 and still keep the sharpness on low, med, high, or off.
They will recycle on the screen with a depth change but eventually these lines will cover the whole screen.
Humminbird says its a software issue (6.740) but has not explained why it just started.
It appears on the water and in simulation mode.
I can work around it but just wondering if anyone else has run into this?
Thanks.
John
[imghttp://][/img]
[/URL][/img]
[/URL][/img]
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: 1198c SI Horizontal lines
« Reply #1 on: April 04, 2014, 09:53:31 PM »
Yes. I have not seen anything that looks better with the sharpness on anyway, but I have that same situation. Bob
« Reply #2 on: April 04, 2014, 11:25:25 PM »
That was a known issue in some of the newer software versions when the DI Enhance Sharpness was set to anything other than Off...
http://www.bbcboards.net/humminbird-sonar-gps/401537-998-di-sharpness-issues.html
I'm not sure if any of the newest versions fixes this...
Offline connbass1
« Reply #3 on: April 05, 2014, 10:41:50 AM »
Thanks for the information. Like I said on my first post I'll work around it.
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #4 on: April 05, 2014, 12:17:20 PM »
Good news is Humminbird's POLITICALLY CORRECT.  Bad news is this BUG was in 6.570 and is still in 6.740.
So we all keep working around it. . .  It's in 998's also.
Sorry
« Last Edit: April 05, 2014, 12:20:24 PM by LittleGazoo »
Last post March 17, 2011, 06:13:45 AM
by felvic
Last post March 01, 2011, 09:06:24 PM
by noisemaker
Last post March 01, 2011, 03:05:47 PM
by Kimi
Last post September 08, 2011, 09:33:36 PM
by lcookie
Last post June 07, 2012, 02:20:38 PM
by rlazop2004
Last post July 03, 2012, 09:41:27 PM
by bomac
Last post January 20, 2013, 02:28:26 AM
by mike fish
Last post May 15, 2015, 12:02:13 AM
