Author Topic: Software for dual beam Humminbird 788ci  (Read 13016 times)
Offline pedro
  • Unit(s): 788ci
« on: August 03, 2011, 03:18:01 AM »
Dear All,
I have a Humminbird 788ci (serial number 9092902-0459) and I tried to record depth data recently. Therefore, I inserted a memory card into one of the available slots and I used the start and stop recording options as explained in the manual. Afterwards, I saw the files recorded in the card: there are some *dat files which seem to point to *son and *idx files saved in separate directories. I searched in your web site and in the internet in general and I found software to read and convert sonar files to other types such as “HBSI sonar data file converter” but all this software seems to work only with side sonar, whereas I have a double beam sonar. I really need to convert the sonar files to some readable format such as text or excel, so that I may recover depth, latitude and longitude data and use it in a Geographical Information System for research purposes. Do you have any advice that may help me?
With my best regards,
Pedro Duarte
Pedro Duarte
Offline drpelle
    • DrDepth mapping
  • Unit(s): 998
Re: Software for dual beam Humminbird 788ci
« Reply #1 on: August 04, 2011, 05:25:36 AM »
Dear All,
DrDepth (www.drdepth.se) will do what you need.
Per
« Reply #2 on: August 04, 2011, 04:06:57 PM »
You can export the open file in humviewer and then from the file tab "export" an excel file .csv......from there you can get your information...If you want to work with the "raw data" and your own program...
Offline pedro
  • Unit(s): 788ci
« Reply #3 on: August 05, 2011, 04:59:10 AM »
Chuck,
Thanks a lot for your suggestion. I have just tried Huminviewer and it seems to work perflectly!
Cheers
Pedro
Pedro Duarte
Offline pedro
  • Unit(s): 788ci
« Reply #4 on: August 05, 2011, 05:22:50 AM »
Chuck,
One more question: the csv file I got has latitude, longitude, then what appears to be depth, then date, time and another two columns. It seems to me that the first of these two columns might be gps elevation and direction of the boat movement. Can you confirm this?
Pedro
Pedro Duarte
Offline pedro
  • Unit(s): 788ci
« Reply #5 on: August 05, 2011, 05:39:31 AM »
Chuck,
Don't bother anymore! I have just seen the meaning of all .csv file contents in the Huminviewer.
Cheers
Pedro
Pedro Duarte
« Reply #6 on: August 05, 2011, 08:19:02 AM »
Pedro.....great....hope the .csv will work fine for you.  We use the export for several different programs and find the data is good....Chuck
Last post November 28, 2011, 07:01:38 PM
by cds2
Last post October 25, 2012, 10:44:27 AM
by harporocks
Last post December 26, 2012, 10:16:08 AM
by ITGEEK
Last post December 29, 2012, 10:31:01 AM
Last post December 11, 2014, 01:11:03 PM
by jimmythegreek
Last post February 27, 2015, 10:28:57 AM
by sblatt
Last post July 14, 2016, 02:53:06 AM
by fishreed
Last post July 19, 2017, 08:50:55 PM
by knorstu
