Author Topic: 998 SI says I have a dual beam transducer  (Read 14514 times)
Offline knorstu
  • I work therefore I fish!
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« on: July 15, 2017, 04:38:40 PM »
Hi. When I look in the networking page, it says I have a dual beam transducer. I don't have down imaging nor side. Tested another transducer is my shop. Says the same but I haven't tried it in the water.
Can I trust what it says in the networking page? I ask because one of those two transducers came with the unit. It is definitely a 998 SI.
Thanks.
Re: 998 SI says I have a dual beam transducer
« Reply #1 on: July 16, 2017, 08:10:07 AM »
The 2d listing under the networking tab indicates there is a 2d piezo in the network (not necessarily a separate 2d xducer) ...
It is recognizing the 2d piezo in the xducer that is connected to the unit  ...
Please verify which xducer you have by the labeling stamped on the xducer cable about 1 foot from the connector end  ...
« Last Edit: July 16, 2017, 08:13:01 AM by rnvinc »
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #2 on: July 16, 2017, 06:06:44 PM »
Thanks. Learn something new all the time.
My cable has it printed on. XHS 9 HDSI 180 T which I believe is correct.
This really makes me wonder why I didn't have the displays. This unit is typically a slave display to my 1197 but I thought I had every screen possible visible.
« Reply #3 on: July 16, 2017, 06:42:45 PM »
Make sure the connected transducer in the setup menu is correct ..... or reset defaults.
« Last Edit: July 16, 2017, 06:43:52 PM by Bob B »
« Reply #4 on: July 16, 2017, 10:25:46 PM »
As Bob noted make sure the Connected Transducer selection(under the Sonar tab) is set to Hi Def SideScan  ...
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #5 on: July 17, 2017, 02:33:07 PM »
I scrolled through every possible transducer in the setup menu. Didn't help.
« Reply #6 on: July 17, 2017, 05:26:49 PM »
What is the connected transducer set at?
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #7 on: July 17, 2017, 06:41:24 PM »
Hi-def
« Reply #8 on: July 17, 2017, 09:02:16 PM »
Please check to see if there is anything listed under the "Advanced" tab in the Networking menu  ...
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #9 on: July 19, 2017, 08:50:55 PM »
Thank you all. The Advanced tab was it. Once I checked the transducer, it worked.
This is what happens when you take your slave unit to Canada!
Last post November 28, 2011, 07:01:38 PM
by cds2
Last post October 25, 2012, 10:44:27 AM
by harporocks
Last post December 26, 2012, 10:16:08 AM
Last post December 29, 2012, 10:31:01 AM
Last post January 31, 2013, 11:06:35 AM
Last post April 08, 2013, 01:29:07 PM
by Warrior12934
Last post December 11, 2014, 01:11:03 PM
by jimmythegreek
Last post July 14, 2016, 02:53:06 AM
by fishreed
