Author Topic: 998 high speed transducer  (Read 21343 times)
Offline Blackwaterkatz
  • Unit(s): 797c si / 998c si / 1198
  • Software: 5.450 / 5.700
  • Accessories: weathersense
« on: July 28, 2011, 07:33:37 PM »
I just haven't had much success getting the SI transducer that came with my unit to read depth at higher speeds; tried a lot of adjustments, but it isn't reliable at speeds above maybe 20 mph.  Can I purchase a different transducer for high speed only, and use it with my unit?
Tommy in Lowcountry S.C.
Offline Roddy
  • Scan,scan and rescan
Re: 998 high speed transducer
« Reply #1 on: July 28, 2011, 11:26:05 PM »
Hi Tommy; We got 9 in rain in 39 hr!
What xducer are you using?
try to post a few inst pix, left,right and aft on close and far.
Good luck and enjdy. Roddy :)
Scan,Scan and Rescan Roddy
« Reply #2 on: July 29, 2011, 09:45:45 AM »
Tom, we are seeing problems with the 190 transducer and transom mount. A lot of folks are opting for a shoot thru the hull for speed depths.
As Roddy requested, can you post pictures of the install...
« Reply #3 on: July 29, 2011, 08:30:18 PM »
I'm using the supplied transducer, which I'm pretty sure is the XHS-9-HDSI-180-T.  It is mounted basically where the 797's XNT-9-SI-180-T was (which read bottom at any speed), and I've adjusted it vertically with no real improvement.  The transducer to the left is for my Lowrance dual freq. which I always keep in the position shown.  I have another 200 mhz on the port side for that unit.
ila_renderedila_rendered
« Reply #4 on: July 29, 2011, 08:32:10 PM »
Not the greatest pics from my cell phone, but hopefully they will show what is there.  Thanks.
Offline Roddy
« Reply #5 on: July 29, 2011, 10:53:01 PM »
Tommy; Might try adjusting the aft end of the xducer up in the mount.
First one slot then one more.  Roddy
« Reply #6 on: July 30, 2011, 08:41:20 PM »
I've already tried changing height, as well as the angle of tilt.  Right now it is at the lowest point that I've tried.  I want to find out if I can install another 200 mhz and just use it for standard down sonar while cruising at speed, then switch to the side imaging transducer for lower speeds.
Offline Roddy
« Reply #7 on: July 31, 2011, 01:39:08 AM »
Hi Tommy; Yes you can install two (2) xducer's with the TS-3 switch from HB .
The switch is about $85.00 +S&H.
Roddy
Offline jgollihar
  • Unit(s): 1197, 998
  • Accessories: interlink
« Reply #8 on: August 11, 2011, 10:28:41 AM »
Why not just purchase a XP 9 20 puck transducer and mount it to shoot thru the hull. You will also need a Y-connector. Plug your existing SI cable into the Y-connector marked SI and your new Puck cable into the Y-connector tail marked Dual Beam. Your unit will automatically run the Dual Beam at high speed.
Now if you are wanting High speed SI images, your probably out of luck.
« Reply #9 on: August 11, 2011, 10:37:55 AM »
I am wondering if using the new T3 switch might not be better than a y-connector.
Thoughts...
Last post July 05, 2014, 11:05:56 AM
by Bryson
Last post March 05, 2012, 07:38:21 AM
by Doc Stressor
by jgcox6
Last post January 03, 2014, 02:59:58 PM
by louisd33
Last post July 05, 2014, 06:41:00 PM
by Trout Bum
Last post June 20, 2015, 11:33:01 AM
by starkyb
Last post September 02, 2016, 08:45:33 AM
Last post July 05, 2017, 12:05:04 AM
