Author Topic: 1197c si high speed transducer  (Read 11153 times)
Offline louisd33
  • Unit(s): 1197 c si, 998 c si
  • Software: not updated yet
  • Accessories: none
« on: January 01, 2014, 09:05:02 PM »
Hello,
I have a 1197c si that I would like to run two transducers with, the si transducer and one for on plane bottom reading
Can someone please tell me which transducer I will require.
Also, I will be adding a 998c si unit to the bow with the si transducer mounted on the trolling motor.
Which is the best way to connect both units?
Thanks,
Louis
Re: 1197c si high speed transducer
« Reply #1 on: January 02, 2014, 02:47:08 PM »
Welcome to the Humminbird Side Imaging Forums Louis.
If you have a fiberglass boat your best chance of getting high-speed depth readings is with an inside-the-hull transducer.  The XP-9-20 is the transducer you will need for this along with the AS-Si-DB-Y cable to connect both transducers to your 1197c Si unit.
To connect the 1197c Si and 998c Si units together you will need an Ethernet Connection Cable (AS-EC-XXE).  These come in different lengths and the length of the cable is in the part number and replaces the “XX”.  So a 2-foot long cable will be the AS-EC-2E, a 10-foot long cable would be the AS-EC-10E and a 20-foot long cable would be the AS-EC-20E.  There is also a 15 and 30 version of the same cable.
Offline louisd33
  • Accessories: none
« Reply #2 on: January 02, 2014, 07:49:16 PM »
My boat is a Lund Pro V, so a through hull is out of the question.
Thanks for the info.
So If I'm understanding this right, with the Ethernet cable I should be able to use either transducer at the Stearn, or the trolling motor from either unit, right ?
Do I need two gps pucks or will one work for both?.
Also do I need two of the identical Navionics cards. I have an older Gold card for the 1197 but will only be able to buythe new larger gold card for the 998 unit.
Thanks for your help,
Louis.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #3 on: January 03, 2014, 02:14:39 AM »
Here is a link to an old post that shows how I rigged the transducer on my Lund. (near the end of the post)
I am able the get good 2D to 20mph this way. May give you some ideas.
          http://forums.sideimagingsoft.com/index.php?topic=4764.msg29554;topicseen#new
« Reply #4 on: January 03, 2014, 12:55:08 PM »
Louis,
With an aluminum hulled boat you would need to use an externally mounted transducer like the XNT-9-20 or do something like newkid4si posted.
Yes, if the units are Ethernet connected you can set one unit to use the other’s transducer.
You will need a second mapping card for your 998c Si unit.  The units read the mapping data right from the map card.  They do not copy it to their internal memory.
Offline louisd33
  • Accessories: none
« Reply #5 on: January 03, 2014, 02:59:58 PM »
Thanks Greg,
You have been a big help.
I was thinking that was the way to go but I have read so many different posts that I was somewhat confused.
It's going to be a long winter waiting to get my set together and back out on the water.
Thanks again.
Louis.
by Bryson
by Doc Stressor
Last post March 07, 2013, 11:25:11 AM
by Captn_C
Last post July 05, 2014, 06:41:00 PM
by Trout Bum
Last post June 20, 2015, 11:33:01 AM
by starkyb
Last post September 02, 2016, 08:45:33 AM
Last post July 05, 2017, 12:05:04 AM
